Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Vista 64-Bit, HP 820CSE and Linksys PPSX1 Print Server Problem
Old 03-03-2007   #1 (permalink)
Brett
I have an ancient HP 820CSE attached to an equally ancient Linksys
PPSX1 version 1 on my home network. The printer and printer server
work fine from my other computers running XP on the network, but when
I try to print from Vista, the printer starts feeding the paper,
hangs, and then eventually shuts down. It does not print, and I do not
get a print error. I have the printer set up on the network as
instructed here:
http://linksys.custhelp.com/cgi-bin/...i=&p_topview=1
which is the same way the other XP computer are set up. I can ping
the print server from Vista just fine.
I've tried deinstalling and reinstalling the printer several times.
Any ideas?
Thanks
Vista and Wireless Print Server - Linksys WPS54G Vista hardware & devices
Linksys Print server Vista hardware & devices
Linksys Print Server Vista print fax & scan
Linksys Print Server Vista General
Vista 64-Bit, HP 820CSE and Linksys PPSX1 Print Server Problem Vista print fax & scan
