Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - c3180 problem
Old 03-14-2007   #1 (permalink)
Chester GS
c3180 problem
Have a new HP computer with vista. Bought a c3180 printer/scanner/copier to
go with it. Software included is only good up to XP, as you probably know.
Downloaded large driver file from HP, which works, but it inisists on
reinstalling itself on every reboot and occasionally at other times. This is
a pain. Anybody else encounter this problem?
Old 03-14-2007   #2 (permalink)
Cari \(MS-MVP\)
Re: c3180 problem
After downloading the software from the HP website, did you disconnect the
all in one before installing the software? If not, you need to completely
uninstall (and disconnect)... then reboot, install the software and don't
connect the unit until the software tells you to do so.
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
http://www.coribright.com/windows
"Chester GS" <ChesterGS@discussions.microsoft.com> wrote in message
news464FCE6-54DD-4DDA-AE98-B213CD82B345@microsoft.com...
> to
> is
problem to install HP all in one C3180 Vista print fax & scan
Hp Photosmart C3180 Problem Vista print fax & scan
HP C3180 Problem Vista hardware & devices
HP C3180 problem Vista hardware & devices
HP C3180 on Vista Vista print fax & scan
