| | Add network printer problem When clicking on add network printer the program crashes immediately and returns the following error: Problem signature: Problem Event Name: APPCRASH Application Name: Explorer.EXE Application Version: 6.0.6000.16386 Application Timestamp: 4549b091 Fault Module Name: StackHash_9da6 Fault Module Version: 6.0.6000.16386 Fault Module Timestamp: 4549bdc9 Exception Code: c0000374 Exception Offset: 000af1c9 OS Version: 6.0.6000.2.0.0.256.6 Locale ID: 7177 Additional Information 1: 9da6 Additional Information 2: fc2f7712529e8b3643d970f531aecdb1 Additional Information 3: 268e Additional Information 4: b8bec0b278f28604e46eff2cdfa9649f |
| | Re: Add network printer problem Are you on a managed (active directory) network or not? There are some known issues in the location code that runs when the wizard does the Active Directory search. To test this you could set the "Number of directory printers" to 0 for the "Add Printer wizard - Network scan page (Managed Network)" policy. To adjust the policy, fire up gpedit & go to "Local Computer Policy \ Computer Configuration \ Administrative Templates \ Printers". The known issues with this location bug depends on some specific AD settings which we can go into if you can confirm that this is the problem. We currently have a fix for said problem in our SP1 builds, so there is a long term solution. Let me know if the above makes a difference & hopefully we can find a short term one as well. Dan "Ernst - EXE Graphics" <ErnstEXEGraphics@discussions.microsoft.com> wrote in message news:C9CBFB4B-7DCA-48D3-A84B-81CC2AD716EE@microsoft.com... > When clicking on add network printer the program crashes immediately and > returns the following error: > > Problem signature: > Problem Event Name: APPCRASH > Application Name: Explorer.EXE > Application Version: 6.0.6000.16386 > Application Timestamp: 4549b091 > Fault Module Name: StackHash_9da6 > Fault Module Version: 6.0.6000.16386 > Fault Module Timestamp: 4549bdc9 > Exception Code: c0000374 > Exception Offset: 000af1c9 > OS Version: 6.0.6000.2.0.0.256.6 > Locale ID: 7177 > Additional Information 1: 9da6 > Additional Information 2: fc2f7712529e8b3643d970f531aecdb1 > Additional Information 3: 268e > Additional Information 4: b8bec0b278f28604e46eff2cdfa9649f > |
| network printer problem | Network & Sharing | |||
| problem with my network printer | Network & Sharing | |||
| Network printer problem | Vista print fax & scan | |||
| Problem with Network printer over wireless network. | Vista print fax & scan | |||
| Network Printer and Wireless Network problem | Vista installation & setup | |||
