Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Lexmark X7350 will not work on wireless network
Old 03-28-2007   #1 (permalink)
ewebber@rogers.com
I have a new Lexmark AIO 7350. It installed OK to my PC with Vista
using USB cable. My laptop with XP works OK using my Linksys router
and adapter card. I can connect to the internet on the laptop OK. BUT
I can't seem to make it recognize and share the printer on the laptop.
Any suggestions to make this work would be greatly appreciated.
EW
Old 03-28-2007   #2 (permalink)
Aspire5610z
Re: Lexmark X7350 will not work on wireless network
On 28 Mar 2007 09:11:53 -0700, ewebber@rogers.com wrote:
See if this helps:
http://support.lexmark.com/cgi-perl/...49&relevance=1
>EW
Can't scan over wireless network with Lexmark x4650 Vista print fax & scan
(Wireless network + USB Lexmark Printer) x Windows Vista = No Inte Vista networking & sharing
lexmark x7350 Vista print fax & scan
lexmark x7350 cant scan & using vista ultimate Vista print fax & scan
Extra Lexmark/Vista drivers available: X7350 Vista print fax & scan
