Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - printing problems
Old 04-03-2007   #1 (permalink)
cj1
printing problems
hi
when i go to print a document it won't let me print it says spooler
subsystem app stopped working. how can i get it working again i really need
to print up some things
thanks cotrice
Old 04-04-2007   #2 (permalink)
Hugh Wyn Griffith
Re: printing problems
In article <69273A77-B79D-466F-92D0-7C989DB7AFA9@microsoft.com>, Cj1 wrote:
> it says spooler*
> subsystem app stopped working. *how can i get it working again i really need*
> to print up some things*
Try going into the Printer Properties and find the TAB that refers to spooling,
then set it to Print Direct to Printer.
If that does it you could try turning back on the spooler after rebooting once
to see if that clears a blockage.
START / ... Control Panel / Printers then right mouse click on your printer
icon and select Properties. Then browse until you find the TAB (Advanced?). But
if you are using the default VISTA driver built into VISTA that TAB may be
grayed out -- mine is -- and I don't know how else you may turn of Print
Spooling. Try looking in HELP for Print Spooler
Old 04-06-2007   #3 (permalink)
Cari \(MS-MVP\)
Same solution as for XP.
http://support.microsoft.com/default...b;en-us;324757
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
http://www.coribright.com/windows
"cj1" <cj1@discussions.microsoft.com> wrote in message
news:69273A77-B79D-466F-92D0-7C989DB7AFA9@microsoft.com...
> hi
> need
> thanks cotrice
Printing problems Vista print fax & scan
Re: ie 7 printing problems Vista print fax & scan
Re: still problems with printing in ie7 Vista print fax & scan
Printing Problems Vista General
Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems Vista installation & setup
