Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - MS Publisher Print Layout Issue
Old 04-07-2007   #1 (permalink)
ray
Hi there,
I am running Vista Home Premium, Publisher 2007, Epson Stylus Photo R800
printer.
i want to print 10 business cards on some precut business card paper. i
designed my card, then when i go to set the print margins, this is where i
have the issue. i set the top margin .5", side margin .75, Horz gap .0", Vert
gap .0", just like the precut sheet. i should see 10 business cards, but only
the top 6 cards show, with room for the 4 other cards, but that area is
blank. i have tried this on laser jet printer as well, with the same results.
i am familiar with publisher and formatting the printer, so i am quite
baffled. i have dug around and looked at every setting i could find, with no
luck. i used the snipping tool to capture an image of the issue, is there a
way to upload that pic?
Thanx for any help
Ray
print issue-x32 lap to x64 desktop Drivers
print issue Vista General
Saving Print Set-up w/Documents in Publisher 2007 .NET General
Publisher Print Error: Cannot Load Printer Driver Vista print fax & scan
print errors -- HP/Vista/Publisher 2007/Xerox printer Vista print fax & scan
