Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Help w/ Printing Properties
Old 04-15-2007   #1 (permalink)
FR3SH
before i installed vista i was able to click print then properties so i could
change how i wanted it to print like fastdraft or print in black ink only now
i cant click the properties and i was wondering how i could get it to work.
thanks
Old 04-16-2007   #2 (permalink)
Cari \(MS-MVP\)
Re: Help w/ Printing Properties
Make and model of printer?
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
http://www.coribright.com/windows
"FR3SH" <FR3SH@discussions.microsoft.com> wrote in message
news:C061A0D8-A7CC-4B92-9DF6-7422C7097AE2@microsoft.com...
> could
> now
> work.
> thanks
Old 04-16-2007   #3 (permalink)
FR3SH
HP 2175 all in one
> Cari (MS-MVP)
> > could
> > now
> > work.
> > thanks
Old 04-16-2007   #4 (permalink)
Cari \(MS-MVP\)
HP say that it's an older printer and they are not going to write updated
drivers for it..... if you read the bottom paragraph:
http://h10025.www1.hp.com/ewfrf/wc/d...=90809&lang=en
You might find that some of the advanced features are no longer available
when using this basic driver. You can upgrade to an HP product that is fully
compatible with Windows Vista if the advanced features are necessary.
They suggest you may wish to upgrade..... probably if you do, it might not
be another HP product.
Cari (MS-MVP)
news:859505F0-73F0-4686-B00C-29C9144F302F@microsoft.com...
> HP 2175 all in one
>> Cari (MS-MVP)
>> > could
>> > only
>> > now
>> > work.
>> > thanks
Old 04-16-2007   #5 (permalink)
Hugh Wyn Griffith
In article <#KNfL1EgHHA.5044@TK2MSFTNGP05.phx.gbl>, Cari (MS-MVP) wrote:
> They suggest you may wish to upgrade..... probably if you do, it might not*
I know how you feel but HP are not the only company behaving like this so
caveat emptor rules in these early days.
Old 04-17-2007   #6 (permalink)
FR3SH
so theres no print properties because I upgraded from xp to vista?
Old 04-17-2007   #7 (permalink)
Hugh Wyn Griffith
In article <8E303444-5B25-4A6C-86B8-02FDB76C5F19@microsoft.com>, Fr3Sh
No that was Cari who posted that.
Well Yes and No <g>
The basic reason may be because to get VISTA out on the streets HP
provided to Microsoft a very basic driver for some of its printers to
be included in VISTA with a view to providing fully featured software
later.
But "Yes", if you had not gone to VISTA you would not have had the
problem if the fully featured driver was available for your printer and
version of Windows.
printing a file created by the windows printing dialog (print to f PowerShell
Modifying OEM properties listed in system properties Vista installation & setup
Trouble Using "properties" option when printing Vista print fax & scan
Printing Properties Vista print fax & scan
Cannot access properties in "local area connection properties" win Vista networking & sharing
