| | Point and Pring Issue in VISTA using Build-in Administrator 1. Install a printer driver on Windows XP 2. Share this printer 3. Logon another VISTA client via Build-in Administrator 4. Drag this printer from the share printer. ==> Vista will pop up an error message that "can't call print monitor..." Use standard user is no problem. This maybe a bug of MS. |
| | Re: Point and Pring Issue in VISTA using Build-in Administrator This is due to User Account Controls being disabled when the administrator account is logged on. Yes this is a bug. -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto This posting is provided "AS IS" with no warranties, and confers no rights. "VOOHOO" <voohoo2000@gmail.com> wrote in message news:1177061005.735100.135340@n59g2000hsh.googlegroups.com... > 1. Install a printer driver on Windows XP > 2. Share this printer > 3. Logon another VISTA client via Build-in Administrator > 4. Drag this printer from the share printer. > > ==> Vista will pop up an error message that "can't call > print monitor..." > > > Use standard user is no problem. This maybe a bug of MS. > |
| | Re: Point and Pring Issue in VISTA using Build-in Administrator But this will work if the driver does not have an associated monitor. -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto This posting is provided "AS IS" with no warranties, and confers no rights. "Alan Morris [MSFT]" <alanmo@online.microsoft.com> wrote in message news:ObuKEv4gHHA.1332@TK2MSFTNGP03.phx.gbl... > This is due to User Account Controls being disabled when the administrator > account is logged on. Yes this is a bug. > > -- > Alan Morris > Windows Printing Team > Search the Microsoft Knowledge Base here: > http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto > > This posting is provided "AS IS" with no warranties, and confers no > rights. > > "VOOHOO" <voohoo2000@gmail.com> wrote in message > news:1177061005.735100.135340@n59g2000hsh.googlegroups.com... >> 1. Install a printer driver on Windows XP >> 2. Share this printer >> 3. Logon another VISTA client via Build-in Administrator >> 4. Drag this printer from the share printer. >> >> ==> Vista will pop up an error message that "can't call >> print monitor..." >> >> >> Use standard user is no problem. This maybe a bug of MS. >> > > |
| 4GB Issue with Vista 64 HP New Build | General Discussion | |||
| Build-in Administrator Account - Clarification ?? | Vista General | |||
| nvlddmkm.sys issue fixed to a point | Vista General | |||
| r800 pring in wierd order | Vista print fax & scan | |||
| Very serious issue with build 5728 | Vista General | |||
