Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Connecting to remote printer on XPSP2
Old 04-24-2007   #1 (permalink)
jn5519
I have a peer to peer network. One computer is Vista Home Basic while the
other is XP home edition. When trying to install a printer on the xp
computer to the vista computer I get the following message: "Cannot conect to
printer, Acces denied". I searched the microsoft knowledgebase and found a
solution, article 934643. the steps outlined to solve the problem apply only
to XP PRO; on XP Home, a more direct modification to the registry would
probably be required. Anyone who has had this problem and a solution?
Old 04-24-2007   #2 (permalink)
muretired
RE: Connecting to remote printer on XPSP2
I am also having the exact same problem with an Epson Stylus C60 inkjet
printer, right down to the same message. Sounds like a Vista problem. How
about some help microsoft.
Old 04-24-2007   #3 (permalink)
Cari \(MS-MVP\)
Re: Connecting to remote printer on XPSP2
Have you worked your way through:
http://www.microsoft.com/technet/net.../vista_fp.mspx
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
http://www.coribright.com/windows
"jn5519" <jn5519@discussions.microsoft.com> wrote in message
news:9A89CF33-7AD5-4D4C-B541-F6D3D4DDCB3C@microsoft.com...
> to
> only
Old 04-25-2007   #4 (permalink)
Alan Morris [MSFT]
One of the network developers had some questions
Is the customer not able to access only printer shares or both file &
printer shares?
Also, if you want to debug the issue, you can request the customer to send
us the output of "net share print$". This would display permissions
associated with print$.
You could ask customer(s) to disable and enable sharing; and see if that
helps.
I would love to know the application that changes the default windows
settings that causes this. Normally the Vista machine can access other
shares on XP only the spool directory has been reconfigured.
could you get me the "net share print$" information from the XP machine?
thanks
Share name print$
Path c:\windows\System32\spool\drivers
Remark Printer Drivers
Maximum users No limit
Users
Caching Manual caching of documents
Permission Everyone, READ
BUILTIN\Administrators, FULL
BUILTIN\Power Users, FULL
The command completed successfully.
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
> to
> only
Old 04-25-2007   #5 (permalink)
Alan Morris [MSFT]
It's a sharing issue on the XP machine. Read the KB article if you have XP
Pro.
http://support.microsoft.com/kb/934643
Error message when you try to add a shared printer to a Windows Vista-based
computer: "Windows cannot connect to the printer. Access is denied"
on the XP machine open a cmd window and type. I expect that the XP machine
information has been modified.
net share print$
you should get something like this
E:\>net share print$
Share name print$
Users
Alan Morris
"muretired" <muretired@discussions.microsoft.com> wrote in message
news:0445159B-D225-48BB-8408-531F67C2FD35@microsoft.com...
>> conect to
>> a
>> only
Old 05-16-2007   #6 (permalink)
LMEHUK
I am having exactly the same issue and it seems there are many out there
also in the same position.
MY Vista machine can see my printers on my XP Home desktop but will not
alllow them to connect.
I looked at "net share print$" and I get everything I'm supposed to apart
from any permissions.
All I get is :
> Share name print$
> Users
I have tried turning the sharing on & off on the prinetr but still no change.
Any ideas?
LH
> printer shares?
> helps.
> thanks
> Share name print$
> Users
> Alan Morris
> > to
> > only
Old 05-16-2007   #7 (permalink)
Alan Morris [MSFT]
Confirm the Vista machine is denied access to \\XPmachine\print$
in a cmd windows type
dir \\XPmachine\print$
If you get access denied.
stop the spooler service on the XP machine, stop sharing the print$ share
(mmc, add snapin, shared folders).
net start spooler
Wait a few minutes then check in the shared folders snapin and confirm the
print$ share was recreated. I have shared printers so if it's not recreated
reshare your printer on XP.
I don't think the network guy was saying stop sharing the printer. He
wanted to disable sharing completely then reenable. It's some network thing
but I don't know exactly what he wanted.
Alan Morris
"LMEHUK" <LMEHUK@discussions.microsoft.com> wrote in message
news:3D716E3F-924D-4729-847F-3DA9D6C43F99@microsoft.com...
> Hi,
> All I get is :
>> Share name print$
>> Users
> change.
> Any ideas?
> LH
>> printer shares?
>> send
>> helps.
>> thanks
>> Share name print$
>> Users
>> Alan Morris
>> rights.
>> >the
>> > conect
>> > to
>> > found a
>> > only
Old 05-16-2007   #8 (permalink)
Michael in Ohio
Hi- I wanted to take a second to jump in here too. I am experiencing the
same conditions. A new laptop with Windows Vista Home Premium.
I have a desktop with Windows XP SR2 with a printer connected to it. All my
other XP computers can connect to it and install the printer. The Vista
machine can see the printer, but will receive an error if I ry to connect to
it.
I tried a work around I found which included installing it as a local
printer. This failed also. I tried the dir \\computername\printername
command in a command window and received "not enough server storage is
available to process this command" I believe received this error also when I
tried to install the network printer as a loca printer.
I could use some advise as well. It certainly seems this would be a simple
process to handle, but with all the similar cases floating around the web, it
doesn't appear to be so. Please help if at all possible.
Thanks
> net start spooler
> Alan Morris
> > Hi,
> > All I get is :
> >> Share name print$
> >> Users
> > change.
> > Any ideas?
> > LH
> >> printer shares?
> >> send
> >> helps.
> >> thanks
> >> Share name print$
> >> Users
> >> Alan Morris
> >> rights.
> >> >the
> >> > conect
> >> > to
> >> > found a
> >> > only
Old 05-17-2007   #9 (permalink)
LMEHUK
Hi ALan,
Thanks for the info.
I do get access denied. I have added the snapin & shared folders but get
access denied when I try to do anything within the shared folders.
Also, I am not able to stop the share on print$. Says its system controlled.
Still have the same problem!!!!
L
> net start spooler
> Alan Morris
> > Hi,
> > All I get is :
> >> Share name print$
> >> Users
> > change.
> > Any ideas?
> > LH
> >> printer shares?
> >> send
> >> helps.
> >> thanks
> >> Share name print$
> >> Users
> >> Alan Morris
> >> rights.
> >> >the
> >> > conect
> >> > to
> >> > found a
> >> > only
Old 05-17-2007   #10 (permalink)
Alan Morris [MSFT]
You need to stop the spooler service first. You will need to be logged on
with administrative privilege to the XP machine
Alan Morris
news:5C354621-02C7-4E06-B864-F82629BDE650@microsoft.com...
> Hi ALan,
> controlled.
> L
>> net start spooler
>> the
>> recreated
>> thing
>> Alan Morris
>> rights.
>> > Hi,
>> > there
>> > apart
>> > All I get is :
>> >> Share name print$
>> >> Users
>> > change.
>> > Any ideas?
>> > LH
>> >> printer shares?
>> >> send
>> >> that
>> >> helps.
>> >> other
>> >> machine?
>> >> thanks
>> >> Share name print$
>> >> Users
>> >> Alan Morris
>> >> rights.
>> >> >the
>> >> > xp
>> >> > conect
>> >> > to
>> >> > found a
>> >> > apply
>> >> > only
>> >> > would
>> >> > solution?
Connecting a Vista laptop to remote printer Vista print fax & scan
Connecting to a remote server with RDP Vista General
Remote Assistance Not Connecting Vista networking & sharing
connecting to different remote servers VB Script
remote desktop connecting???? Vista networking & sharing
