Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Printer problem with Vista
Old 05-08-2007   #1 (permalink)
Dwaggie67
Everytime I want to configure my printer I get this error.
Problem Event Name: APPCRASH
Application Name: Explorer.EXE
Application Version: 6.0.6000.16386
Application Timestamp: 4549b091
Fault Module Name: StackHash_9e9c
Fault Module Version: 6.0.6000.16386
Fault Module Timestamp: 4549bdc9
Exception Code: c0000374
Exception Offset: 000af1c9
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Additional Information 1: 9e9c
Additional Information 2: 60220326995ea42703c547324416c000
Additional Information 3: cc17
Additional Information 4: e592ba8aff3fb0990fba34b6a01747b2
Or if I even try to print something I get it.
Old 05-08-2007   #2 (permalink)
Cari \(MS-MVP\)
Re: Printer problem with Vista
Make and model of printer? Which drivers are you using?
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
http://www.coribright.com/windows
"Dwaggie67" <Dwaggie67@discussions.microsoft.com> wrote in message
news:35392805-0949-4CA0-9EFC-B0BADDE2C82F@microsoft.com...
> Locale ID: 1033
Old 05-09-2007   #3 (permalink)
Alan Morris [MSFT]
If you are using HP Universal Printer driver (I think the PCL 5 one). The
explorer process will crash when the printer is a connection.
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
"Cari (MS-MVP)" <NewsGroups@coribright.com> wrote in message
news:OSsQsNekHHA.1532@TK2MSFTNGP03.phx.gbl...
> Cari (MS-MVP)
>> Locale ID: 1033
Old 05-09-2007   #4 (permalink)
Dwaggie67
I have a HP Photosmart 7260 printer. As for the driver its a Hewlett-Packard
when I click on driver details it says No driver file are required or have
been loaded for this device.
> Cari (MS-MVP)
> > Locale ID: 1033
Old 05-09-2007   #5 (permalink)
Cari \(MS-MVP\)
Did you follow the instructions at:
http://h10025.www1.hp.com/ewfrf/wc/d...305337&lang=en
Is this an upgrade to Vista or a clean install?
Cari (MS-MVP)
news:0200C67B-B16B-4F66-8E33-17C358B3153D@microsoft.com...
>Hewlett-Packard
>> Cari (MS-MVP)
>> > Locale ID: 1033
Problem with Dell printer after installation of Vista SP2 (printer prints an extra page) Vista General
Vista/Printer problem Windows Updates
Another printer problem with Vista Vista print fax & scan
Printer problem in Vista Vista General
Lexmark Printer / Error problem communicating with printer Vista print fax & scan
