Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Print Spooler will not start
Old 05-17-2007   #1 (permalink)
splatt
I have a windows Vista laptop and am trying to connect to a network printer.
I have the RPC service and Print Spooler service set to automatic, but the
print spooler service does not seem to be starting when I reboot the
computer. When I manually start it, I can print once, then it will stop
again. Any suggestions?
Old 05-17-2007   #2 (permalink)
Alan Morris [MSFT]
Re: Print Spooler will not start
Faulty or corrupt drivers is the primary reason for spooler terminations.
What driver are you using anyway? If it's inbox, delete the printer and
driver and reinstall.
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
"splatt" <splatt@discussions.microsoft.com> wrote in message
news:9C148C13-8B67-4FD5-A85A-A3B802E74CB9@microsoft.com...
>printer.
Old 05-18-2007   #3 (permalink)
splatt
I have checked the mfr website. They do not have a Vista driver I can
download. It says that the driver is integrated into Vista. I have tried
deleting and re-installing, but I continue to have the problem.
Old 05-21-2007   #4 (permalink)
Alan Morris [MSFT]
What device is this for? What is the exact driver name?
Are there any other print driver you don't need that can be deleted from the
machine?
Alan Morris
news:43C4CF9F-CA20-4459-A0EA-E54FE9CE9DDC@microsoft.com...
Old 05-21-2007   #5 (permalink)
splatt
Looks like JP LaserJet 1012 Version 5.60.1604.0
I tried to run the software update on the driver page. It took me to the HP
site, but it wasn't working right.
I think I may have gotten the issue resolved. I have restarted twice now
and it seems to have connected both times. I don't know what the issue was,
but whatever it was seems to have resolved itself. Go Figure.
If it appears again, I will post to this thread.
Thanks for your help
HOw do I start the print spooler so I can install my print drivers? Vista installation & setup
Print Spooler hangs and doesn't print Vista print fax & scan
Print Spooler Locks up After first Print Vista hardware & devices
Print Spooler Lock up After first Print Vista General
Ref print spooler Vista General
