Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista Tutorial - Connecting a Vista machine to a printer shared on an XP machine.
Old 05-23-2007   #11 (permalink)
Michael in Ohio
Guest
Re: Connecting a Vista machine to a printer shared on an XP machin
Hi Alan,
I did as you suggested. Set the key to 50 and the printer connected.
Backed it down to 21 and settled there. Thanks again. Please consider
posting these errors and the IRPStack fix on the Knowledge Base as I have
heard a number of similar cases.
Thanks again.
"Alan Morris [MSFT]" wrote:
> The instructions say to increase by 3
> So set the key
> reboot
> retry the connection
> fails
> change the key by adding 3
> reboot
> fails
> repeat
> I'd set it to 50 first, if that works set to 25. If that fails go up 3. If
> 25 works you can tweak it but you know the default 15 does not.
> Alan Morris
> Windows Printing Team
> Search the Microsoft Knowledge Base here:
> http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
> This posting is provided "AS IS" with no warranties, and confers no rights.
> "Michael in Ohio" <MichaelinOhio@discussions.microsoft.com> wrote in message
> news:3F82FBE9-7823-4A29-BBD2-FBD3DDBCEB81@microsoft.com...
> > Yes, the machine has been rebooted a number of times.
> > Norton System Works Premier 2005 with Norton Anti Virus Version 11.0.16.2
> >> Did you reboot the XP machine? The setting is for the server service
> >> which
> >> is a layer between the spooler on one machine communicating with the
> >> spooler
> >> on the other machine
> >> What Anti Virus software are you using?
> >> Alan Morris
> >> rights.
> >> message
> >> news:38D76294-A1B4-499F-B38B-0837F0F56AAF@microsoft.com...
> >> > Alan,
> >> > I did as instructed, no change. Exact same errors exist. There was
> >> > not a
> >> > value esablished for the IRPStack. I added it per the instructions and
> >> > set
> >> > it to 3. No change. I went back in and reset it to 15. Also no
> >> > change.
> >> >> I knew this was posted previously. You need to fix the IRPStack on
> >> >> the
> >> >> XP
> >> >> machine.
> >> >> Thanks for including the complete error.
> >> >> http://support.microsoft.com/default...;EN-US;q177078
> >> >> Cool
> >> >> the error evaluates to
> >> >> E:\>winerror 1130
> >> >> 1130 ERROR_NOT_ENOUGH_SERVER_MEMORY <--> 0xc0000205
> >> >> STATUS_INSUFF_SERVER_RESOURCES
> >> >> I have no clue what an IRPStack is.
> >> >> Alan Morris
> >> >> rights.
> >> >> "George J Meier" <jost@meierNOCAPITALS.screaming.net> wrote in message
> >> >> news:ulM1Ag67GHA.4304@TK2MSFTNGP03.phx.gbl...
> >> >> > Hurrah ! Hurrah !
> >> >> > I finally found the solution !
> >> >> > Went to:
> >> >> > http://support.microsoft.com/default...EN-US;q177078&
> >> >> > On the XP machine, on which the printer is connected, I increased
> >> >> > Increas"IRPStackSize" from the existing 11 to 14 (increment of 3)
> >> >> > according to recommensdation.
> >> >> > And could install the Printer, No Sweat.
> >> >> > Georgio, again.
> >> >> > message
> >> >> > news:e9N2F957GHA.3760@TK2MSFTNGP02.phx.gbl...
> >> >> >> How can you recommend to anybody to switch to Vista RC2 ?
> >> >> >> On existing Local Home Networks, it is impossible to share printers
> >> >> >> attached to Win XP Pro Boxes.
> >> >> >> When trying to add those printers (on a Windows Workgroup
> >> >> >> Network),one
> >> >> >> gets an Error message:
> >> >> >> Eroor Code 0x0000046a.
> >> >> >> How can one even consider changing over to Vista? in those
> >> >> >> circomstances?
> >> >> >> Georgio
> >> >> Alan Morris
> >> >> rights.
> >> >> message
> >> >> news:293383A3-CB4A-4AEB-AB64-A149C06D8CB9@microsoft.com...
> >> >> > Hi Alan,
> >> >> > In the Add Printer window, my printer is shown. I attempt to
> >> >> > connect
> >> >> > to
> >> >> > it
> >> >> > and receive the following error: [Connect To Printer] Windows
> >> >> > cannot
> >> >> > connect
> >> >> > to the printer. Operation could not be completed (error 0x0000046a)
> >> >> > If I attempt to set up a New Printer, Local Printer, New Port,
> >> >> > \\computername\printername, I receve the following error: [Local
> >> >> > Port]
> >> >> > Not
> >> >> > enough server storage is available to process this command.
> >> >> > I don't if I mentioned, but I can see my shared files and folders on
> >> >> > the
> >> >> > XP
> >> >> > machine and have no problems accessing the files.
> >> >> > Thanks,
> >> >> >> When do you get the error and what is the exact error message you
> >> >> >> receive
> >> >> >> on
> >> >> >> the Vista machine when making the connection.
> >> >> >> Yes this will work if we add a local printer to the Vista machine
> >> >> >> using
> >> >> >> the
> >> >> >> inbox driver. But the exact error first please.
> >> >> >> Alan Morris
> >> >> >> rights.
> >> >> >> in
> >> >> >> message
> >> >> >> news:162EC8C4-B333-4B1E-855C-A17CCE8AC448@microsoft.com...
> >> >> >> > Hi Alan,
> >> >> >> > I do not have this file on my Windows XP machine. To clarify,
> >> >> >> > the
> >> >> >> > HP5510
> >> >> >> > All In One printer is installed on the Windows XP machine with
> >> >> >> > the
> >> >> >> > Vista
> >> >> >> > Laptop trying to connect to it.
> >> >> >> > When looking at the Driver section of the Printer, the only
> >> >> >> > driver
> >> >> >> > which
> >> >> >> > is
> >> >> >> > Check Marked is the [Enviorment] Intel [Version] Windows 2000 or
> >> >> >> > XP.
> >> >> >> > I
> >> >> >> > thought perhaps that I should download a Vista driver and
> >> >> >> > maintain
> >> >> >> > it
> >> >> >> > on
> >> >> >> > the
> >> >> >> > XP machine, but HP doesn't make this available as it is already
> >> >> >> > shipped
> >> >> >> > with
> >> >> >> > Vista.
> >> >> >> > I know the Vista Driver is available on the laptop, but I never
> >> >> >> > get
> >> >> >> > far
> >> >> >> > enough in the process to use the driver.
> >> >> >> > Where to from here?
> >> >> >> > Thanks,
> >> >> >> >> dir \\computer\printshare is an invalid command.
> >> >> >> >> Thanks for the driver name. HP has a binary that checks the OS
> >> >> >> >> version.
> >> >> >> >> The binary only works on Server 2003 and less OS version
> >> >> >> >> numbers.
> >> >> >> >> This
> >> >> >> >> binary will terminate when run in Vista. Since the file is
> >> >> >> >> loaded
> >> >> >> >> with
> >> >> >> >> the
> >> >> >> >> driver, the terminating code causes the spooler to fail on
> >> >> >> >> Vista.
> >> >> >> >> Check
> >> >> >> >> the
> >> >> >> >> version number of hpbmini.dll on you XP machine
> >> >> >> >> \windows\system32\spool\drivers\w32x86\3. The version number
> >> >> >> >> should
> >> >> >> >> be
> >> >> >> >> 18
> >> >> >> >> or greater to work on Vista.
> >> >> >> >> Alan Morris
> >> >> >> >> no
> >> >> >> >> rights.
> >> >> >> >> wrote
> >> >> >> >> in
> >> >> >> >> message
> >> >> >> >> news:90FDAB14-0F4A-4FCC-BEE2-17C9AD944D66@microsoft.com...
> >> >> >> >> >I am experiencing the same conditions as many others. I'd like
> >> >> >> >> >to
> >> >> >> >> >work
> >> >> >> >> > through it with someone if there is anyone who can help. I
> >> >> >> >> > have a
> >> >> >> >> > new
> >> >> >> >> > laptop
> >> >> >> >> > with Windows Vista Home Premium.
> >> >> >> >> > I have a desktop with Windows XP SR2 with an HP5510 printer
> >> >> >> >> > connected
> >> >> >> >> > to
> >> >> >> >> > it.
> >> >> >> >> > All my other XP computers can connect to it and install the
> >> >> >> >> > printer.
> >> >> >> >> > The
> >> >> >> >> > Vista
> >> >> >> >> > machine can see the printer, but will receive an error if I
Old 08-24-2007   #12 (permalink)
Gary Sakaguchi
Guest
Alan,
I'm having a problem when printing powerpoint 2007 (more than six pages)
from a Vista machine through a W2003 Server SP2. On the Dell W5310 printer
it gives a "900.00 SERVICE RIP SOFTWARE" error. If I print less than six
pages it's ok. I also created a local TCP/IP printer and it will print all
27 pages from the same Vista pc.
Gary Sakaguchi
> So set the key
> reboot
> fails
> reboot
> fails
> repeat
> Alan Morris
> >> which
> >> spooler
> >> Alan Morris
> >> rights.
> >> message
> >> > Alan,
> >> > not a
> >> > set
> >> > change.
> >> >> the
> >> >> XP
> >> >> machine.
> >> >> Cool
> >> >> E:\>winerror 1130
> >> >> Alan Morris
> >> >> rights.
> >> >> > Hurrah ! Hurrah !
> >> >> > Went to:
> >> >> > Georgio, again.
> >> >> > message
> >> >> >> Network),one
> >> >> >> circomstances?
> >> >> >> Georgio
> >> >> Alan Morris
> >> >> rights.
> >> >> message
> >> >> > Hi Alan,
> >> >> > connect
> >> >> > to
> >> >> > it
> >> >> > cannot
> >> >> > connect
> >> >> > Port]
> >> >> > Not
> >> >> > the
> >> >> > XP
> >> >> > Thanks,
> >> >> >> receive
> >> >> >> on
> >> >> >> using
> >> >> >> the
> >> >> >> Alan Morris
> >> >> >> rights.
> >> >> >> in
> >> >> >> message
> >> >> >> > Hi Alan,
> >> >> >> > the
> >> >> >> > HP5510
> >> >> >> > the
> >> >> >> > Vista
> >> >> >> > driver
> >> >> >> > which
> >> >> >> > is
> >> >> >> > XP.
> >> >> >> > I
> >> >> >> > maintain
> >> >> >> > it
> >> >> >> > on
> >> >> >> > the
> >> >> >> > shipped
> >> >> >> > with
> >> >> >> > Vista.
> >> >> >> > get
> >> >> >> > far
> >> >> >> > Where to from here?
> >> >> >> > Thanks,
> >> >> >> >> version.
> >> >> >> >> numbers.
> >> >> >> >> This
> >> >> >> >> loaded
> >> >> >> >> with
> >> >> >> >> the
> >> >> >> >> Vista.
> >> >> >> >> Check
> >> >> >> >> the
> >> >> >> >> should
> >> >> >> >> be
> >> >> >> >> 18
> >> >> >> >> Alan Morris
> >> >> >> >> no
> >> >> >> >> rights.
> >> >> >> >> wrote
> >> >> >> >> in
> >> >> >> >> message
> >> >> >> >> >to
> >> >> >> >> >work
> >> >> >> >> > have a
> >> >> >> >> > new
> >> >> >> >> > laptop
> >> >> >> >> > connected
> >> >> >> >> > to
> >> >> >> >> > it.
> >> >> >> >> > printer.
> >> >> >> >> > The
> >> >> >> >> > Vista
Old 08-24-2007   #13 (permalink)
Alan Morris [MSFT]
Guest
no clue on this. It feels like a driver issue but Dell would need to
investigate. HP had an issue with Excel or Word in the latest Office
version that caused an Error 49 on several of their devices. They gave us
an updated driver for this class of device.
RIP stands for Raster Imaging Process so it appears to be a formatting or
processing error.
So why does direct printing work? Can you install PowerPoint on the server
and send the 27 job successfully to the printer?
You could also configure the server print queue such that Advanced Printing
Features is disabled on the Advance tab of the printer properties. This
will force all job formatting on the client.
What print processor does this device expect (also on the Advanced tab)?
From the printer doc:
900-999 Service <message>
1.. Turn the printer off.
2.. Unplug the power cord from the wall outlet.
3.. Check all cable connections.
4.. Connect the power cord to a properly grounded outlet.
5.. Turn the printer back on.
If the service message recurs, call for service, and report the
message number and description of the problem.
Alan Morris
"Gary Sakaguchi" <GarySakaguchi@discussions.microsoft.com> wrote in message
news:52110D40-9AEE-4B49-8BA6-78611C86D826@microsoft.com...
> Alan,
> printer
> all
> Gary Sakaguchi
>> So set the key
>> reboot
>> fails
>> reboot
>> fails
>> repeat
>> If
>> Alan Morris
>> rights.
>> message
>> > 11.0.16.2
>> >> which
>> >> spooler
>> >> Alan Morris
>> >> rights.
>> >> message
>> >> > Alan,
>> >> > not a
>> >> > and
>> >> > set
>> >> > change.
>> >> >> the
>> >> >> XP
>> >> >> machine.
>> >> >> Cool
>> >> >> E:\>winerror 1130
>> >> >> Alan Morris
>> >> >> rights.
>> >> >> message
>> >> >> > Hurrah ! Hurrah !
>> >> >> > Went to:
>> >> >> > Georgio, again.
>> >> >> > message
>> >> >> >> printers
>> >> >> >> Network),one
>> >> >> >> circomstances?
>> >> >> >> Georgio
>> >> >> Alan Morris
>> >> >> rights.
>> >> >> in
>> >> >> message
>> >> >> > Hi Alan,
>> >> >> > connect
>> >> >> > to
>> >> >> > it
>> >> >> > cannot
>> >> >> > connect
>> >> >> > 0x0000046a)
>> >> >> > Port]
>> >> >> > Not
>> >> >> > on
>> >> >> > the
>> >> >> > XP
>> >> >> > Thanks,
>> >> >> >> you
>> >> >> >> receive
>> >> >> >> on
>> >> >> >> machine
>> >> >> >> using
>> >> >> >> the
>> >> >> >> Alan Morris
>> >> >> >> no
>> >> >> >> rights.
>> >> >> >> wrote
>> >> >> >> in
>> >> >> >> message
>> >> >> >> > Hi Alan,
>> >> >> >> > the
>> >> >> >> > HP5510
>> >> >> >> > the
>> >> >> >> > Vista
>> >> >> >> > driver
>> >> >> >> > which
>> >> >> >> > is
>> >> >> >> > or
>> >> >> >> > XP.
>> >> >> >> > I
>> >> >> >> > maintain
>> >> >> >> > it
>> >> >> >> > on
>> >> >> >> > the
>> >> >> >> > already
>> >> >> >> > shipped
>> >> >> >> > with
>> >> >> >> > Vista.
>> >> >> >> > never
>> >> >> >> > get
>> >> >> >> > far
>> >> >> >> > Where to from here?
>> >> >> >> > Thanks,
>> >> >> >> >> OS
>> >> >> >> >> version.
>> >> >> >> >> numbers.
>> >> >> >> >> This
>> >> >> >> >> loaded
>> >> >> >> >> with
>> >> >> >> >> the
>> >> >> >> >> Vista.
>> >> >> >> >> Check
>> >> >> >> >> the
>> >> >> >> >> should
>> >> >> >> >> be
>> >> >> >> >> 18
>> >> >> >> >> Alan Morris
>> >> >> >> >> confers
>> >> >> >> >> no
>> >> >> >> >> rights.
>> >> >> >> >> wrote
>> >> >> >> >> in
>> >> >> >> >> message
>> >> >> >> >> >like
>> >> >> >> >> >to
>> >> >> >> >> >work
>> >> >> >> >> > have a
>> >> >> >> >> > new
>> >> >> >> >> > laptop
>> >> >> >> >> > connected
>> >> >> >> >> > to
>> >> >> >> >> > it.
>> >> >> >> >> > printer.
>> >> >> >> >> > The
>> >> >> >> >> > Vista
Old 11-27-2008   #14 (permalink)
Newbie
Vista Home Premium
Re: Connecting a Vista machine to a printer shared on an XP machine.
I have the same problem as the first post, but can somebody please simplify the rest, seems to go on forever and difficult to see what solutions are there.
Thanks
Old 11-27-2008   #15 (permalink)
Malke
Guest
> Thanks
Boris - Because you are using a web interface that leeches Usenet newsgroup
posts - *not* a real forum - the rest of us who are using real newsreaders
don't see the thread to which you refer. We don't see what you do. Since
you didn't quote any of the original problem, I don't have any of the
details necessary to help you.
Please create a new post with all pertinent details about your system and
the issue per the "How to Post" section below. Also consider using a
newsreader to access Usenet. This is very easy to do. See the information
below.
Since you are using a web interface, you may not realize that this is really
a newsgroup. You will get far more out of this resource if you learn to use
a newsreader. There are many good newsreaders for Windows, but you can use
Outlook Express (XP) or Windows Mail (Vista) since you already have it.
Here are some links to information about newsgroups:
About Usenet:
http://en.wikipedia.org/wiki/Usenet
http://www.faqs.org/faqs/ - Usenet FAQs from the Internet FAQ Archives
http://www.usenetmonster.com/infocenter/
http://www.elephantboycomputers.com/page2.html#Usenet - a brief explanation
of newsgroups
Outlook Express/Windows Mail as Newsreader:
http://michaelstevenstech.com/outloo...snewreader.htm
http://rickrogers.org/setupoe.htm
http://vistasupport.mvps.org/accessi...ndows_mail.htm
How to Post:
http://support.microsoft.com/default.aspx/kb/555375 - How to Ask a Question
http://users.tpg.com.au/bzyhjr/liszt.htm - How Not to Get Technical Help on
Usenet
http://www.catb.org/~esr/faqs/smart-questions.html
http://aumha.org/nntp.htm - list of MS newsgroups
microsoft.public.test.here - MS group to test if your newsreader is working
properly
http://www3.telus.net/dandemar/munad.htm - how to munge email address
http://en.wikipedia.org/wiki/Crossposting - crossposting
http://www.blakjak.demon.co.uk/mul_crss.htm - multiposting
Other Newsreaders for Windows:
http://www.forteinc.com/main/homepage.php - Forte
http://www.mozilla.org - Thunderbird
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
FAQ - http://www.elephantboycomputers.com/#FAQ
Shared Network Printer - Can't Connect From Vista Machine Vista General
Vista Machine unable to print to Printer attached to 98 machine thru parallel port Network & Sharing
CAn't Print To a Shared Printer on XP Machine Vista networking & sharing
Shared Printer connected to an XP machine Vista General
New Windows Vista Machine Connecting to a USB Printer on an XP Mac Vista networking & sharing
