| | Print Queue Problem I have an LaserJet 1200 printer connected to a Netgear FR114P print server/router. When I send a print job from my Vista Business laptop to the printer, the queue does not clear when the job is done. I have to manually clear it to prevent the job from re-printing. What is the solution to this? Thank you. Frustrated in Seattle |
| | Re: Print Queue Problem The most obvious potential cause is in the printer settings. Try: 1) Right click on the printer & select Properties 2) Select the Advanced Tab 3) The checkbox for "Keep printed documents" should be unchecked. If that's not it, let us know & we'll take another look. Dan "bluepete" <bluepete@discussions.microsoft.com> wrote in message news:256C07C9-5393-46C5-A99B-47BF665B8DA3@microsoft.com... >I have an LaserJet 1200 printer connected to a Netgear FR114P print > server/router. When I send a print job from my Vista Business laptop to > the > printer, the queue does not clear when the job is done. I have to manually > clear it to prevent the job from re-printing. What is the solution to > this? > Thank you. > > Frustrated in Seattle |
| | Re: Print Queue Problem Since this is an HP device make sure you follow the instructions from Netgear. Disable Bi-directional on the Ports tab since it is not supported with this device. http://kbserver.netgear.com/inquira/...25#__highlight -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto This posting is provided "AS IS" with no warranties, and confers no rights. "Dan [MSFT]" <djanni@microsoft.com> wrote in message news:OaglcrtnHHA.3772@TK2MSFTNGP03.phx.gbl... > The most obvious potential cause is in the printer settings. Try: > > 1) Right click on the printer & select Properties > 2) Select the Advanced Tab > 3) The checkbox for "Keep printed documents" should be unchecked. > > If that's not it, let us know & we'll take another look. > > Dan > > "bluepete" <bluepete@discussions.microsoft.com> wrote in message > news:256C07C9-5393-46C5-A99B-47BF665B8DA3@microsoft.com... >>I have an LaserJet 1200 printer connected to a Netgear FR114P print >> server/router. When I send a print job from my Vista Business laptop to >> the >> printer, the queue does not clear when the job is done. I have to >> manually >> clear it to prevent the job from re-printing. What is the solution to >> this? >> Thank you. >> >> Frustrated in Seattle > > |
| | Re: Print Queue Problem Thanks, Alan! Disabling bi-directional support on the port did the trick. "Alan Morris [MSFT]" wrote: > Since this is an HP device make sure you follow the instructions from > Netgear. Disable Bi-directional on the Ports tab since it is not supported > with this device. > > > http://kbserver.netgear.com/inquira/...25#__highlight > > -- > Alan Morris > Windows Printing Team > Search the Microsoft Knowledge Base here: > http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto > > This posting is provided "AS IS" with no warranties, and confers no rights. > > "Dan [MSFT]" <djanni@microsoft.com> wrote in message > news:OaglcrtnHHA.3772@TK2MSFTNGP03.phx.gbl... > > The most obvious potential cause is in the printer settings. Try: > > > > 1) Right click on the printer & select Properties > > 2) Select the Advanced Tab > > 3) The checkbox for "Keep printed documents" should be unchecked. > > > > If that's not it, let us know & we'll take another look. > > > > Dan > > > > "bluepete" <bluepete@discussions.microsoft.com> wrote in message > > news:256C07C9-5393-46C5-A99B-47BF665B8DA3@microsoft.com... > >>I have an LaserJet 1200 printer connected to a Netgear FR114P print > >> server/router. When I send a print job from my Vista Business laptop to > >> the > >> printer, the queue does not clear when the job is done. I have to > >> manually > >> clear it to prevent the job from re-printing. What is the solution to > >> this? > >> Thank you. > >> > >> Frustrated in Seattle > > > > > > > |
| Print jobs stuck on Print queue | Network & Sharing | |||
| Print job in queue gets port from next print job | Vista print fax & scan | |||
| Print Queue Logging | VB Script | |||
| After printing several documents, the print queue hangs, print st | Vista print fax & scan | |||
| Re: Print hangs in queue | Vista print fax & scan | |||
