| | Printing Problem I have Vista on a laptop with an HP Laserjet 1320 connected. I log onto remote computer running XP Pro via remote desktop. The printer I have connected to my laptop is not in the list to select when I try to print something. My other laptop which runs XP Pro works fine. I can see the printer on my Vista running laptop, I can print documents directly from my Vista running laptop to the printer. Just no luck when trying to print Vista to XP. |
| Printing Problem | Live Mail | |||
| Re-printing problem | Drivers | |||
| Printing problem | Vista print fax & scan | |||
| printing problem | Vista General | |||
| printing problem | Vista print fax & scan | |||
