| | Epson printer problem I'm having trouble getting my Epson Stylus Photo 810 inkjet printer working on windows Vista. Carn't find any drivers on the Epson site or anywhere else, is there a work around for this. Thanks in advance |
| | Re: Epson printer problem It's not a US model. What country are you from? Or more appropriately, what is the country of origin of said Epson 810? -- Cari (MS-MVP) Windows Technologies - Printing & Imaging http://www.coribright.com/windows "jogga" <jogga@37.com> wrote in message news:%23prdEIipHHA.4188@TK2MSFTNGP02.phx.gbl... > I'm having trouble getting my Epson Stylus Photo 810 inkjet printer > working > on windows Vista. > Carn't find any drivers on the Epson site or anywhere else, is there a > work > around for this. Thanks in advance > |
| | Re: Epson printer problem On Sun, 3 Jun 2007 21:59:19 +0100, "jogga" <jogga@37.com> wrote: >I'm having trouble getting my Epson Stylus Photo 810 inkjet printer working >on windows Vista. >Carn't find any drivers on the Epson site or anywhere else, is there a work >around for this. Thanks in advance I hate to tell you this, there is no workaround. Try installing the XP driver and cross your fingers. |
| | Re: Epson printer problem On Sun, 3 Jun 2007 19:04:20 -0700, "Cari \(MS-MVP\)" <NewsGroups@coribright.com> wrote: >It's not a US model. What country are you from? Or more appropriately, what >is the country of origin of said Epson 810? Australia/Asia |
| | Re: Epson printer problem I am in UK - I have the same Epson Stylus Photo 810 printer and, after getting into problems last week using the XP installation disk on my new Vista laptop, I found that the the Epson website says don't use your XP installation disk on Vista. So I contacted Epson support and I reproduce their clear and v helpful response below. .....Please be advised that unfortunately we have not produced any updated drivers for your printer for Windows Vista. There are however, alternative drivers included as part of your operating system. To install these drivers please follow the instructions below: 1. From the Desktop select Start > Control Panel. 2. In the Control Panel select Printers. 3. In the Printers window click on Add Printer this will bring up the Add Printer wizard. 4. Select "Add Local Printer". 5. Select the correct Port for your Printer and click the "Next" button until you arrive at the screen entitled "Install the Printer Driver". 6. This screen will be split into two parts. On the left hand side you will need to pick the Manufacturer, in this case EPSON. On the right hand side select the model of your printer, when you have selected the options click the "Next" button to continue. 7. Keep clicking "Next" leaving all the settings at default until you reach the final screen where you will need to select "Finish"...... The printer now works happily - and I note that the properties screen for the printer says that it has the Epson Stylus Photo (M) driver installed. I can also drive it over my home wireless network when it is connected to my desktop (and this is my normal mode of operating). Hope this helps "jogga" <jogga@37.com> wrote in message news:%23prdEIipHHA.4188@TK2MSFTNGP02.phx.gbl... > I'm having trouble getting my Epson Stylus Photo 810 inkjet printer > working > on windows Vista. > Carn't find any drivers on the Epson site or anywhere else, is there a > work > around for this. Thanks in advance > |
| | #6 (permalink) |
| | Re: Epson printer problem Abe - please see my response to the original question - there is an extremely simple solution within Vista - and crossing your fingers won't make the XP driver work! "Abe" <noone@nowhere.com> wrote in message news 2j763da0kh4ja6jankftfne5nuvsgohn4@4ax.com...> On Sun, 3 Jun 2007 21:59:19 +0100, "jogga" <jogga@37.com> wrote: > >>I'm having trouble getting my Epson Stylus Photo 810 inkjet printer >>working >>on windows Vista. >>Carn't find any drivers on the Epson site or anywhere else, is there a >>work >>around for this. Thanks in advance > > I hate to tell you this, there is no workaround. Try installing the XP > driver and cross your fingers. |
| | #7 (permalink) |
| | Re: Epson printer problem >>>I'm having trouble getting my Epson Stylus Photo 810 inkjet printer >>>working >>>on windows Vista. >>>Carn't find any drivers on the Epson site or anywhere else, is there a >>>work >>>around for this. Thanks in advance >> >> I hate to tell you this, there is no workaround. Try installing the XP >> driver and cross your fingers. >Abe - please see my response to the original question - there is an >extremely simple solution within Vista - and crossing your fingers won't >make the XP driver work! My apologies. I didn't know Vista supported the Epson 810 out of the box. I had gone to their website and and saw no Vista drivers for it, so I made a wrong assumption.. |
| | #8 (permalink) |
| | Re: Epson printer problem Hi Thanks for your help. I followed your instructions and my Epson printer is printing correctly in windows vista now Your help was much appreciated Thanks again "jogga" <jogga@37.com> wrote in message news:%23prdEIipHHA.4188@TK2MSFTNGP02.phx.gbl... > I'm having trouble getting my Epson Stylus Photo 810 inkjet printer > working > on windows Vista. > Carn't find any drivers on the Epson site or anywhere else, is there a > work > around for this. Thanks in advance > |
| Epson R300 printer | Vista hardware & devices | |||
| epson cx5500 printer | Vista print fax & scan | |||
| Epson R210 Printer | Vista hardware & devices | |||
| Re: Epson 950 printer | Vista print fax & scan | |||
| epson cx7800 printer driver install problem | Vista hardware & devices | |||
