Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Maximum Print size, (200 Inch Limitation)
Old 06-26-2007   #1 (permalink)
Stefan
Currently Windows NT has a maximum print size of 200 Inches by 200 Inches.
Has this page size restriction been increased or removed in Windows Vista?
This limitation prevents the creation of files, such as PDF's, tiff & jpeg's
larger than 200 inches.
See excerpt from Adobe's web site:
Distiller 5.x supports the creation of PDF files with pages up to 200 inches
by 200 inches in size. Due to a limitation with page size storage in Windows
95 and 98, the actual maximum page size will be limited to 129 inches by 129
inches. The maximum page size for Windows NT and for Mac OS is still 200
inches by 200 inches.[268654]
http://kb.adobe.com/selfservice/micr...8111&stateId=0 0 53724809
We currenlty use third party software to plot hard copy drawings 36 inch by
300 inch and would like to make PDF files of the print output. The drawing is
truncated at 200 inches in Windows XP. =-( Can Vista help us on this topic?
HD Maximum size ? Vista hardware & devices
maximum file size VB Script
Is there a limitation to the size of files that can be transfered Vista General
message / send or receive size limitation Vista mail
Briefcase size limitation? Vista General
