Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Scanner will not work
Old 06-28-2007   #1 (permalink)
mikerapolas
I installed Vista on 5/2. i have an Epson CX6400 all in one.
Up until 10 days ago my scanner was working properly. Now it will not scan.
I am told that I do not have "Microsoft WPD filesystems volume driver".
I tried to update this and I am told that my driver is up to date. ??? No
scanner.
I have reinstalled the software for the printer. No scanner. It looks to me
to be a Microsoft Vista problem. But I don't know.
Can anyone help me or try to poine me in the right direction?
Thank you so much.
Sincerely, Mike
Thank you so much, Mike
Old 06-28-2007   #2 (permalink)
Cari \(MS-MVP\)
Re: Scanner will not work
Use System Restore to go back 11 days and see if it works correctly.
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
http://www.coribright.com/windows
"mikerapolas" <mrapolas@tampabay.rr.com(donotspam)> wrote in message
news:4D92F271-8AC1-486E-B604-3C5873A6E432@microsoft.com...
> scan.
> scanner.
> me
> Thank you so much.
> Sincerely, Mike
Old 06-29-2007   #3 (permalink)
mikerapolas
Hi Cari,
I tried to use system restore. I went to the site and the only restore
points I had were for that day. They did not go back any further. Am I doing
something wrong? At least on XP I was able to look at a calendar to see the
restore point dates.
What am I doing wrong?
> Cari (MS-MVP)
> > scan.
> > scanner.
> > me
> > Thank you so much.
> > Sincerely, Mike
Hp scanner won't work on vista Vista hardware & devices
scanner won't work Vista print fax & scan
Scanner will not work Vista performance & maintenance
Scanner does not work Vista installation & setup
Scanner does not work Vista General
