Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Problem with 3180 solved
Old 07-04-2007   #1 (permalink)
Pat B
I found a Windows Installer Patch, KB933828.msp that when I applied it and
then reinstalled my HP software, everything worked. Maybe this will help
somebody else who is having a similar problem.
Pat B
Old 07-06-2007   #2 (permalink)
Evelyn H
RE: Problem with 3180 solved
Hi, Pat:
Where did you find this installer patch KB933828? I have not been able to
install my C3180 printer, and it's frustrating. Thanks.
> Pat B
Old 07-06-2007   #3 (permalink)
Alan Morris [MSFT]
Re: Problem with 3180 solved
this is a pointer to the application issue.
http://support.microsoft.com/default...b;en-us;933828
Error message when you try to print from Works 8 to a Windows Vista-based
computer: "Microsoft Works 8 has stopped working"
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
"Evelyn H" <Evelyn H@discussions.microsoft.com> wrote in message
news:1B057BAD-D543-4D9D-A24E-15B92AED37CA@microsoft.com...
> Hi, Pat:
>> and
>> Pat B
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
XFX 680i SLI problem solved Graphic cards
DVD problem solved Vista General
problem with HP 3180 software Vista print fax & scan
Problem solved Vista mail
