Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Set print quality in Office 2003 using HP PSC2210
Old 07-07-2007   #1 (permalink)
knj
How can I set the print quality to default to print draft instead of normal
as I did using Office 2000 & W 2K
Old 07-09-2007   #2 (permalink)
Cari \(MS-MVP\)
Re: Set print quality in Office 2003 using HP PSC2210
File, Print, click on the properties of the printer.
BTW there are NGs for both Windows 2000 and for Office (general), you are
currently posting in the Vista Printing NGs.
Cari (MS-MVP) Windows Client - Printing & Imaging
www.coribright.com/Windows
"knj" <knj@discussions.microsoft.com> wrote in message
news:B6B50EAF-D34A-4514-9358-AA6DB0BC7056@microsoft.com...
> normal
Old 07-09-2007   #3 (permalink)
knj
> > normal
> Thanks but that only sets it for that time it reverts back to "normal". What are BTW & NGs.
Old 07-09-2007   #4 (permalink)
Cal Bear '66
BTW = By The Way
NG = NewsGroup
I Bleed Blue and Gold
GO BEARS!
news:15FD6F48-022F-4CB2-B134-4D0D88E7E8DF@microsoft.com...
>> > normal
>> What are BTW & NGs.
Old 07-16-2007   #5 (permalink)
Dan [MSFT]
Knj,
If you go to the printers folder (Control Panel -> Printers) and change the
preferences there, they should "stick". This depends somewhat on the
driver, but works for everything that I've seen.
Dan
>> > normal
>> What are BTW & NGs.
High Quality Print Services for Businesses, Small or Large Vista print fax & scan
Problem Report -Office Stopped Working - Office 2003 Pro Vista General
Microsoft Office 2003 compatibility - Specifically - Access 2003! Vista General
Photo Gallery print quality Vista music pictures video
Office 2003 Prompts for Agreement Every Time I start an Office App Vista installation & setup
