Problem with HP 1210
  1. #1
    RJA Guest
    I have an HP psc 1210 All-In-One printer on my Vista machine. I cannot
    access the “printing preferences” window. When I select it, it flashes
    briefly and goes away. I have removed and re-installed, but nothing has
    changed. And yes, I am logged in as administrator. Any suggestions?
    Thanks
  2. #2
    Alan Morris [MSFT] Guest
    Re: Problem with HP 1210
    If you are using the HP Universal Print driver be sure to pick up the most
    recent version.
    Alan Morris
    Windows Printing Team
    Search the Microsoft Knowledge Base here:
    http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
    "RJA" <RJA@discussions.microsoft.com> wrote in message
    news:95E546EC-9D60-4CE5-B7F2-3DA63F83F4DC@microsoft.com...
    > access the "printing preferences" window. When I select it, it flashes
    > Thanks
  3. #3
    huwyngr Guest
    In article <95E546EC-9D60-4CE5-B7F2-3DA63F83F4DC@microsoft.com>, Rja
    wrote:
    > HP psc 1210 All-In-One printer on my Vista machine. *I cannot*
    > access the printing preferences window.
    Is that part of Advanced Features?
    See:
    http://h10025.www1.hp.com/ewfrf/wc/d...8543&lc=en&cc=
    us&dlc=en&product=90764&lang=en
    Using the advanced printer functions
    You might find that some of the advanced features are no longer
    available when using this basic driver. You can upgrade to an HP
    product that is fully compatible with Windows Vista if the advanced
    features are necessary.
  4. #4
    redman Guest
    RE: Problem with HP 1210
    I have same problem and had long UNHELPFUL email exchange with HP tech
    support. The only useful info is that HP and MS are working on a solution
    and I will be advised when it is available. I've also foung that I cannot
    print from Adobe
    > Thanks
Problem with HP 1210 problems?
Solved Lexmark E210/Samsung ML-1210 yonny Drivers 17 19 Mar 2012
Canon Laser Shot LBP-1210 printer problem anuz General Discussion 2 05 Dec 2008
Samsung ML-1210: Haven't seen this problem before SAM Vista print fax & scan 1 31 Mar 2008
psc 1210 all in one printer - Label Problem Bill Vista print fax & scan 6 12 Oct 2007
psc 1210 all in one printer Bill Vista print fax & scan 5 08 Oct 2007
