Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Re: IE7 Print Problem
Old 07-25-2007   #1 (permalink)
PA Bear
Crossposted to Vista Print/Fax/Scan newsgroup.
Is there an HP Director update available for this machine?
~Robear Dyer (PA Bear)
MS MVP-Windows (IE, OE, Security, Shell/User)
AumHa VSOP & Admin; DTS-L.org
cewrx7r1 wrote:
> My new PC with Premium Home Addition prints fine everywhere, except it
> will
> not print paper from IE7. The printer is a simple/cheap HP Deskjet 3845.
> I can print XPS from IE7.
> How to fix this problem?
Old 08-01-2007   #2 (permalink)
cewrx7r1
Discovered that if I "disable/turn off" the PROTECTED MODE in IE7 for
INTERNET,
the print function will work.
Old 08-07-2007   #3 (permalink)
rani
Curiously, if you choose to run IE7 as an
Administrator it lets you print ok.
> INTERNET,
Old 08-07-2007   #4 (permalink)
cewrx7r1
I am logged in as ADMIN!
> > INTERNET,
Old 08-07-2007   #5 (permalink)
Cal Bear '66
Not really. You are and "Administrative User".
Right click on the IE7 icon, and select "Run as Administrator" (elevated).
I Bleed Blue and Gold
GO BEARS!
"cewrx7r1" <cewrx7r1@discussions.microsoft.com> wrote in message
news:49D1C0B3-CC8F-4F23-8BDA-0FE307C359FA@microsoft.com...
>> > INTERNET,
Print Problem Live Mail
I can't print - spooler problem Vista print fax & scan
Print Wizard Problem Vista General
print driver successfully installed but still a problem with print Vista print fax & scan
Can't Print Problem General Discussion
