Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - HP Photosmart printer problem fixed
Old 07-27-2007   #1 (permalink)
HB
FYI...
The problem was in the Port IP Address. I went into the printer setup menu
(using printer keypad) - network - network settings, to find the IP address
(I printed it). Then I right clicked the printer icon under Control
Panel - printers. Went into Configure to find that the IP addresses did
not match. I changed it to match what I got from the network settings.
Printer has been working like a charm for a few days now.
HB
Printer driver neededfor HP Photosmart printer...help Vista print fax & scan
photosmart hp printer Vista networking & sharing
HP Printer PhotoSmart 8230 Vista print fax & scan
HP Photosmart Printer C-5180 Vista hardware & devices
