| | printer problem (in network config) I have a (wireless) network, in which I also have a Digitus DN 11004 router print server. To be able to use the print server, I need to install a SW (USB printer server). I did this for a Windows XP & a Win98 PC. I was able to use my HP deskjet printer without any problem. Now I got a new Vista PC, and I would like to do the same. I installed the SW (without problems). After the SW is installed, you need to add a printer port when creating a new printer. This works on win98 & XP, but when I try to add a local port on Vista, I get following error message: "Specified port cannot be added. Operation could not be completed (error 0x00000578)" (although I see the port shown in the pull down list of the "create a new port"-pull down menu). I checked the site of Digitus, but could not find a specific Vista version of the SW (which seems to run OK, and even can find my printer, but cannot be added to the printer port configuration). I can print on the printer, sharing the printer on the windows XP PC, bbut I cannot print directly on the printer on my Vista PC Can someone help, please? Thanks |
| | Re: printer problem (in network config) Can you not add it via it's TCP/IP address? -- Cari (MS-MVP) Windows Technologies - Printing & Imaging http://www.coribright.com/windows "Koen" <Koen@discussions.microsoft.com> wrote in message news:564B0A93-60B3-4A1E-B1BA-54EC13263BAE@microsoft.com... >I have a (wireless) network, in which I also have a Digitus DN 11004 router > print server. To be able to use the print server, I need to install a SW > (USB > printer server). > > I did this for a Windows XP & a Win98 PC. I was able to use my HP deskjet > printer without any problem. > > Now I got a new Vista PC, and I would like to do the same. I installed the > SW (without problems). After the SW is installed, you need to add a > printer > port when creating a new printer. This works on win98 & XP, but when I try > to > add a local port on Vista, I get following error message: "Specified port > cannot be added. Operation could not be completed (error 0x00000578)" > (although I see the port shown in the pull down list of the "create a new > port"-pull down menu). > > I checked the site of Digitus, but could not find a specific Vista version > of the SW (which seems to run OK, and even can find my printer, but cannot > be > added to the printer port configuration). > > I can print on the printer, sharing the printer on the windows XP PC, bbut > I > cannot print directly on the printer on my Vista PC > > Can someone help, please? > > Thanks |
| | Re: printer problem (in network config) this is the error G:\>winerror 0x00000578 1400 ERROR_INVALID_WINDOW_HANDLE <--> No NTSTATUS matched when you add the software on XP is there another window that pops up that you do not see on Vista. The vendor might be throwing dialog to session 0 which is not the default in Vista. -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto This posting is provided "AS IS" with no warranties, and confers no rights. "Koen" <Koen@discussions.microsoft.com> wrote in message news:564B0A93-60B3-4A1E-B1BA-54EC13263BAE@microsoft.com... >I have a (wireless) network, in which I also have a Digitus DN 11004 router > print server. To be able to use the print server, I need to install a SW > (USB > printer server). > > I did this for a Windows XP & a Win98 PC. I was able to use my HP deskjet > printer without any problem. > > Now I got a new Vista PC, and I would like to do the same. I installed the > SW (without problems). After the SW is installed, you need to add a > printer > port when creating a new printer. This works on win98 & XP, but when I try > to > add a local port on Vista, I get following error message: "Specified port > cannot be added. Operation could not be completed (error 0x00000578)" > (although I see the port shown in the pull down list of the "create a new > port"-pull down menu). > > I checked the site of Digitus, but could not find a specific Vista version > of the SW (which seems to run OK, and even can find my printer, but cannot > be > added to the printer port configuration). > > I can print on the printer, sharing the printer on the windows XP PC, bbut > I > cannot print directly on the printer on my Vista PC > > Can someone help, please? > > Thanks |
| | Re: printer problem (in network config) Dear Alan, I do not recall that a new window popped up in XP. I tried the solution proposed by Cari, and initially it seemed like it worked, although I could not print. Then I remembered a response on another item in here (the conflict between using network printers directly, after the printer has been used also as a shared printer on an XP), and I restored my system to the version prior to my trials of adding the printer. After doing this, I could use the printer. Thanks, Cari & Alan, Koen "Alan Morris [MSFT]" wrote: > this is the error > > G:\>winerror 0x00000578 > 1400 ERROR_INVALID_WINDOW_HANDLE <--> No NTSTATUS matched > > > when you add the software on XP is there another window that pops up that > you do not see on Vista. The vendor might be throwing dialog to session 0 > which is not the default in Vista. > > -- > Alan Morris > Windows Printing Team > Search the Microsoft Knowledge Base here: > http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto > > This posting is provided "AS IS" with no warranties, and confers no rights. > > "Koen" <Koen@discussions.microsoft.com> wrote in message > news:564B0A93-60B3-4A1E-B1BA-54EC13263BAE@microsoft.com... > >I have a (wireless) network, in which I also have a Digitus DN 11004 router > > print server. To be able to use the print server, I need to install a SW > > (USB > > printer server). > > > > I did this for a Windows XP & a Win98 PC. I was able to use my HP deskjet > > printer without any problem. > > > > Now I got a new Vista PC, and I would like to do the same. I installed the > > SW (without problems). After the SW is installed, you need to add a > > printer > > port when creating a new printer. This works on win98 & XP, but when I try > > to > > add a local port on Vista, I get following error message: "Specified port > > cannot be added. Operation could not be completed (error 0x00000578)" > > (although I see the port shown in the pull down list of the "create a new > > port"-pull down menu). > > > > I checked the site of Digitus, but could not find a specific Vista version > > of the SW (which seems to run OK, and even can find my printer, but cannot > > be > > added to the printer port configuration). > > > > I can print on the printer, sharing the printer on the windows XP PC, bbut > > I > > cannot print directly on the printer on my Vista PC > > > > Can someone help, please? > > > > Thanks > > > |
| Network Printer problem | Vista print fax & scan | |||
| problem with my network printer | Network & Sharing | |||
| Problem migrating local user account (not listed) to SBS 2003 domainaccount using SBS Network Config. Wizard | Vista networking & sharing | |||
| Problem with Network printer over wireless network. | Vista print fax & scan | |||
| Network Printer and Wireless Network problem | Vista installation & setup | |||
