Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Lexmark 1270 problems
Closed Thread
Thread Tools Display Modes
Old 09-08-2007   #1 (permalink)
neversez
Guest
I have an Acer TravelMate 4200 with Windows Vista and a Lexmark 1270 (printer
scanner copier). I have downloaded the drivers for it from the lexmark
website but everytime i plug in the usb cable to use it it tries to download
the drivers for xp etc. And wont let me use the printer. keeps saying problem
communicating with printer. Does anyone know how i can stop it downloading
the other drivers?
Sez
Old 09-08-2007   #2 (permalink)
Cari \(MS-MVP\)
Guest
Re: Lexmark 1270 problems
You need to install the Lexmark software before you connect the printer to
the notebook.
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
http://www.coribright.com/windows
"neversez" <neversez@xxxxxx> wrote in message
news898A246-EFBE-435E-9DF3-676B5669386D@xxxxxx
>(printer
> download
> problem
> downloading
> the other drivers?
> Sez
Old 09-08-2007   #3 (permalink)
neversez
Guest
I already have installed the software . i have used the printer already but
cannot get it to print anything now. the scanner part work but the computer
always says cannot communicate with the printer. everytime we plug it in it
tries to reinstall the drivers for xp/2000 etc.
Sez
"Cari (MS-MVP)" wrote:
> the notebook.
> Cari (MS-MVP)
> >(printer
> > download
> > problem
> > downloading
> > the other drivers?
> > Sez
Old 09-08-2007   #4 (permalink)
Cal Bear '66
Guest
You could try this:
Locate the file INFCACHE.1 in C:\Windows\inf
Right click on the INFCACHE.1 file, select Properties >Security > Edit, and give
your account full control.
Delete INFCACHE.1, or rename it to INFCACHE.1.BAK or temporarily move to your
desktop.
REBOOT
I Bleed Blue and Gold
GO BEARS!
news:959905DA-FA71-4CCE-957A-6DF89C3F88BD@xxxxxx
> Sez
>> the notebook.
>> Cari (MS-MVP)
>> >(printer
>> > download
>> > problem
>> > downloading
>> > the other drivers?
>> > Sez
Closed Thread
Display Modes
lexmark Deb Vista print fax & scan 0 12-20-2007 05:51 AM
need software to install a lexmark 1270 kat Vista print fax & scan 1 07-16-2007 05:42 AM
Lexmark Drivers for Lexmark 2300 series printers Bob Lucas Vista General 1 06-01-2007 03:52 PM
Lexmark Z13? ian Vista print fax & scan 1 10-31-2006 12:45 PM
Lexmark all in one problems =?Utf-8?B?NGV2cm5lbGxh?= Vista General 2 07-31-2006 10:34 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
