Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista Tutorial - HP Deskjet 3820 Installed but does not print
Old 09-18-2007   #1 (permalink)
Alex Boromisa
Guest
Hi
I've got Compaq Presario running on Windows Vista Basic. I installed HP
Deskjet 3820 Printer successfully but it will not print.
Problem is that when I click on "Print" button I get notification that the
document was sent to the printer but it does not print. Interesting thing is
that when I try to access printer properities it does not allow me to do so -
it just flashes.
I once succeeded in printing out test or demo page but nothing else will
print.
Your help is greatly appreciated.
Regards
Alex Boromisa
Old 09-22-2007   #2 (permalink)
Prakash
Guest
RE: HP Deskjet 3820 Installed but does not print
I will help you resolve your issue.
Here is the solution...
1. Connect the printer to your computer.
2. Click on Start button >> Control Panel >> Hardware and Sound >> Printers.
3. Click Add a printer.
4. In the Add Printer Wizard, select Add a local printer.
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select USB001 virtual printer
port and then click Next.
7. On the Install the printer driver page, select the printer manufacturer
HP (not Hewlett-Packard) and the printer name Deskjet 970cse, and then click
Next.
8. Select "Replace the current driver" and click Next and then Finish.
I hope, this should resolve the issue.
Please get back to me if the issue persists...
I'll be waiting for your response....
Old 09-24-2007   #3 (permalink)
Alex Boromisa
Guest
Thank you very much it was helpful and I really appreciate your assistance.
I realized myself that problem was in driver due to time difference between
printer (XP) and PC (Vista) and sought to find replacement. However, HP
website suggested that I should install HP Photosmart Basic Print Driver/HP
Photosmart 7150 Printer. That didn’t help as my printer printed out blank
pages. This one is great and it works.
http://h10025.www1.hp.com/ewfrf/wc/s...s=2093&lang=en
Have a nice day and thank you again you saved me!
Kind Regards
Alex
> Next.
Old 05-04-2008   #4 (permalink)
Chatek
Guest
"Alex Boromisa" wrote:
Quote:
> Hi
> it just flashes.
> print.
> Regards
> Alex Boromisa
Oh My God!
I've got the same printer and the same problem!
I've installed it but now when i try to print the window for print opens but
nothing happens!
When I try to acces printer options just the small window flashes.. Any
suggestions?
Old 05-04-2008   #5 (permalink)
Chatek
Guest
OMG.
You rock!
Thank you sooo much!
I was trying to solve this for two weeks and I didn't know how... I have
almost gone to the shop and bought a new printer..
Thank you..
You saved my life.. Thanks again..
Old 11-20-2008   #6 (permalink)
Cari \(MS-MVP\)
Guest
Re: HP Deskjet 3820 Installed but does not print
What (if anything) does the HP Printing Diagnostic test tell you?
http://h10025.www1.hp.com/ewfrf/wc/s...=75045&lang=en
Cari (MS-MVP) Printing & Imaging
www.coribright.com/windows
"asearch4reason" <asearch4reason@xxxxxx> wrote in message
news:C791CA96-A584-4B5D-9876-490774D7344C@xxxxxx
Quote:
> well...did not work for me...all it does is put a question mark by the
> device
> in DEVICE MANAGER.....any other advise!!!! really starting to get
> frustrating....
Quote:
>> Hi
>> the
>> is
>> so -
>> it just flashes.
>> print.
>> Regards
>> Alex Boromisa
Old 08-19-2009   #7 (permalink)
Newbie
32bit
Deskjet 970cse- Problem Solved
Quote  Quote: Originally Posted by Prakash View Post
Next.
Which driver for HP Deskjet 3820? Vista print fax & scan
Vista doesn't print to an old HP Deskjet 870Cse printer (parallelconnection)... Vista General
Vista doesn't print to an old HP Deskjet 870Cse printer (parallelconnection)... Vista hardware & devices
Vista doesn't print to an old HP Deskjet 870Cse printer (parallelconnection)... Vista print fax & scan
Vista print dialog conflicts for HP Deskjet 970xci Vista print fax & scan
