| | Remote Printer Problem I have a Samsung CLP-550 attached to an XP MCE machine and it works properly. When I attempt to access it from another machine that is running Vista Premium, it doesn't show on the list of printers. I then; Open Control Panel->Printers Add a Network Printer. This shows the SamsungColor on SRV (its shared) When I try to add it, I'm told to install the printer driver I accept UAC and the install attempts to connect to the remote printer I get a dialog saying that it it Connecting to.. then, I get an error that "Windows cannot connect to the printer. There is not enough memory to complete this operation. Close programs and try again." I suspect the message is bogus since the Vista machine has 2gb of memory and the XP machine has 1gb available. Any help would be appreciated. Mike |
| | Re: Remote Printer Problem MikeM wrote: Quote: > I have a Samsung CLP-550 attached to an XP MCE machine and it works properly. > When I attempt to access it from another machine that is running Vista > Premium, it doesn't show on the list of printers. I then; > Open Control Panel->Printers > Add a Network Printer. This shows the SamsungColor on SRV (its shared) > When I try to add it, I'm told to install the printer driver > I accept UAC and the install attempts to connect to the remote printer > I get a dialog saying that it it Connecting to.. then, > I get an error that "Windows cannot connect to the printer. There is not > enough memory to complete this operation. Close programs and try again." > > I suspect the message is bogus since the Vista machine has 2gb of memory and > the XP machine has 1gb available. Install them on your Vista machine. Now do the Add/Printer routine. Since you see the printer when you go through the Add Printer wizard, I assume that you have properly set up file/printer sharing between the XP MCE and Vista machines. If you are uncertain about this, review the information at this link: http://www.microsoft.com/technet/net.../vista_fp.mspx Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| | Re: Remote Printer Problem I did as you instructed and downloaded the file 20070128170053390_CLP-550_GDI_Vista.exe from the site. When I installed it, it created a local printer on the Vista machine. I removed that one and tried to install the remote printer. It failed in the same was as originally. BTW, I think I already had the driver installed because the install program said it was repairing it. Mike "Malke" wrote: Quote: > MikeM wrote: Quote: > > I have a Samsung CLP-550 attached to an XP MCE machine and it works properly. > > When I attempt to access it from another machine that is running Vista > > Premium, it doesn't show on the list of printers. I then; > > Open Control Panel->Printers > > Add a Network Printer. This shows the SamsungColor on SRV (its shared) > > When I try to add it, I'm told to install the printer driver > > I accept UAC and the install attempts to connect to the remote printer > > I get a dialog saying that it it Connecting to.. then, > > I get an error that "Windows cannot connect to the printer. There is not > > enough memory to complete this operation. Close programs and try again." > > > > I suspect the message is bogus since the Vista machine has 2gb of memory and > > the XP machine has 1gb available. > Go to Samsung's website and download Vista drivers for the printer. > Install them on your Vista machine. Now do the Add/Printer routine. > > Since you see the printer when you go through the Add Printer wizard, I > assume that you have properly set up file/printer sharing between the XP > MCE and Vista machines. If you are uncertain about this, review the > information at this link: > > http://www.microsoft.com/technet/net.../vista_fp.mspx > > > Malke > -- > Elephant Boy Computers > www.elephantboycomputers.com > "Don't Panic!" > MS-MVP Windows - Shell/User > |
| How to connect to XP Remote Printer from Vista | Vista print fax & scan | |||
| Connecting to remote printer on XPSP2 | Vista print fax & scan | |||
| remote printer sharing | Vista networking & sharing | |||
| Remote Desktop problem with remote printers | Vista networking & sharing | |||
| Linking to remote printer does not work | Vista hardware & devices | |||
