| | RE: Vista print spooler problem with MC2400W and MC2430DL printers I understand your concern.. This is the problem with Microsoft. Okay, leave it.. I will help you resolve your issue. I understand that you are able to print only after restarting the computer. Am I correct? If it is, then follow the steps below: Follow the steps below to restart the spooler. 1. Click Start >>All Programs >> Accessories >> Run. 2. Type, SERVICES.MSC in the box and press Ok. It will open one window with so many services listed. 3. Search for the service "Print Spooler". 4. Right-click on Print Spooler >> Click on Restart. And, then 1.Click Start, and right-click Computer. 2.Click Properties, then click Hardware. (or you can see the Device Manager directly here on the lefthand pane) 3.Click Device Manager. 4.Double-click the Universal Serial Bus Controllers branch to expand it. 5.Right-click USB Root Hub, and then click Properties. 6.Click Power Management. 7.De-select the Allow the computer to turn off this device to save power check box. Note: If the Root Hub is listed twice in the Device Manger, perform the steps 5 to 7 on the second entry. 8.Click OK, and close Device Manager. After that, please restart the computer and then try to print. I hope, this should resolve the issue. Please let me know the result..... |
| Windows vista print spooler problem. | Vista General | |||
| Vista 32 bit Print spooler problem? | Vista print fax & scan | |||
| Vista print spooler problem | Vista print fax & scan | |||
| print spooler problem with Vista | Vista General | |||
| Vista print spooler problem | Vista General | |||
