Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Printer problem
Old 10-07-2007   #1 (permalink)
Sub-amateur hackerJoe
Printer problem
Had no prior problems, Lexmark X4270 printer stopped in middle of small print
out - after ejecting one page. Got notice: "AIOC has stopped working" and
it offered to search net for a fix. Then it vanished. Checked
troubleshooting section in Lexmark help , but indicated printer was "ready".
Vista will do almost anything but the laundry, but in doesn't seem to
understand when I try to talk to it. I had difficulties a little way back -
but finally downloaded the correct driver from Lexmark. I still have an
4019 IBM laser printer (by Lexmark) and can't get a driver that works in
Vista. Now, I can't print anything. This whole Vista experience is a
humbling one, and I'm beginning to feel like an idiot. Please, somebody
help. Mucho grassy in advance.
Old 10-08-2007   #2 (permalink)
Cari \(MS-MVP\)
Re: Printer problem
First thing to do is uninstall and reinstall the printer... it sounds like
the drivers have become corrupted.
http://www.coribright.com/windows/Article_One.htm
Lexmark should have an uninstall utility on their website to make sure you
get rid of all the driver remnants.
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
"Sub-amateur hackerJoe" <SubamateurhackerJoe@xxxxxx>
wrote in message news:48118219-4577-4FC7-A274-856F5DB870D6@xxxxxx
> print
> and
> "ready".
> back -
Old 10-09-2007   #3 (permalink)
paininmybutt
RE: Printer problem
I can't get my printer to print, what is the manufactuers drive? It's running
a test page,but nothings on the page!
Old 10-11-2007   #4 (permalink)
Cari \(MS-MVP\)
Re: Printer problem
A little more info needed.
Make and model of printer? When did it last work correctly? Does it have
enough ink in it? etc etc
Cari (MS-MVP)
"paininmybutt" <paininmybutt@xxxxxx> wrote in message
news:5A965852-46F8-4075-9FE1-22938C2A14AF@xxxxxx
>running
Problem with Dell printer after installation of Vista SP2 (printer prints an extra page) Vista General
printer problem to domain's printer Vista General
Printer problem Vista General
Add printer problem Vista print fax & scan
Lexmark Printer / Error problem communicating with printer Vista print fax & scan
