| | Is there a problem with Vista printing? I've heard that there might be some serious issues with printing to XP connected printers. Is that true? My own case, I have an wifi-connected XP Pro workstation connected with an HP G85 printer connected to it. The workstation uses a network cable to connect to the wireless router. I have been printing to it just fine through an XP laptop. Now, with the new Vista laptop, I can connect to the shared printer just fine but the test print fails. I know that the job is getting there ok because I can pause the printer and see the job show up in the print queue. But then it is deleted from the print queue without being printed. I checked to see if there is a special driver that is needed and they say there is not. Any suggestions? Thank you, Geoff |
| | Re: Is there a problem with Vista printing? I kept my desktop on XP for a long time as I needed up upgrade hardware for it to run with Vista.... my husband's PC, my desktop and my test PC were all running Vista and I had no problems in printing to the desktop with any of them.... but I'm a Canon inkjet user, not an HP one. I also had a Lexmark laser printer attached to the desktop (also on a lan card) and again, it printed fine from any PC. Now the desktop is running Vista Ultimate and still none of them have any printing problems. I have an old notebook that still runs XP. No problems there either. Did you work your way through: http://technet.microsoft.com/en-us/l.../bb727037.aspx -- Cari (MS-MVP) Windows Technologies - Printing & Imaging http://www.coribright.com/windows "neophyte" <neophyte@xxxxxx> wrote in message news:A87F742F-5E00-47F2-BDC3-BE507D88B845@xxxxxx Quote: > I've heard that there might be some serious issues with printing to XP > connected printers. Is that true? > > My own case, I have an wifi-connected XP Pro workstation connected with an > HP G85 printer connected to it. The workstation uses a network cable to > connect to the wireless router. I have been printing to it just fine > through > an XP laptop. Now, with the new Vista laptop, I can connect to the shared > printer just fine but the test print fails. I know that the job is getting > there ok because I can pause the printer and see the job show up in the > queue. But then it is deleted from the print queue without being printed. > I > checked to see if there is a special driver that is needed and they say > there > is not. > > Any suggestions? > > Thank you, > > > Geoff |
| | Re: Is there a problem with Vista printing? I came across a wonderful document on the Canon website for VISTA downloads for a Canon printer I was asked about recently which described in very clear detail how to set up a network enabled Canon printer in VISTA. It was illustrated with screen shots and included the two things I have seen stated elsewhere although I've no experience of setting up a networked printer or all in one myself: 1 -- You have to make an installation on the VISTA "remote" PC of a local printer 2 -- You have to set the port being used to a specific description, not the old LPTn of course or even a DOT4 .... Here's a link to the pdf file of instructions -- download it and see if it helps: ftp://ftp.minolta- qms.com/pub/crc/out_going/manuals/misc/km_vista_instruct.pdf See what you think! |
| Vista network printing problem | Vista print fax & scan | |||
| 16-bit printing problem with Vista | Vista print fax & scan | |||
| Printer problem printing from vista to XP | Vista print fax & scan | |||
| problem printing in vista | Vista installation & setup | |||
| Problem printing in IE7 in Vista | Vista print fax & scan | |||
