The problem that I'm having is that I'm unable to get the command line
secpol.msc program to run. I'm logged on as admin and it still tells me it
cannot find the program. Something to that effect.
I can still navigate in control panel to run the app but why does it not run
from the run box or cmd box?
Have I messed up my ENV variables and it is just not in the path statement
or what?
Any clues....Anybody?
Thanks in advance for a reply, Sid
To perform the following procedure, you must be able to log on with or
provide the credentials of a member of the localAdministrators group.
To enable or disable application setup detection in UAC
Click Start, click All Programs, click Accessories, click Run, type
secpol.msc in the Open box, and then click OK.
From the Local Security Policy tree, click Local Policies, and then
double-click Security Options.
Scroll down and double-click User Account Control: Detect application
installations and prompt for elevation.
Choose the appropriate setting:
To enable application setup detection, click Enabled.
To disable application setup detection, click Disabled.
Click OK.
Close the Local Security Policy window.
Sid
"The force be with you"
