Go Back   Vista Forums > Vista Newsgroups > Vista security
Vista - Live Onecare help help
Old 12-11-2007   #1 (permalink)
Barb
I renewed my subscription for windows live onecare all went ok, then for some
unknown reason all of a sudden when I go into Onecares it does not respond,
?? status shows green good but theres no tune up or any other normal info on
screen and I cannot access onecare or its help centre. Im still waiting for
tech support to contact me. Ive restarted, checked for viruses all kinds,
does any one have an answer please
Old 12-11-2007   #2 (permalink)
StephenB
Re: Live Onecare help help
You probably upgraded to v 2.0 this past week. There have been some problems for
a small percentage of people - little consolation if you are one of the few
people.
You may want to consider uninstalling and reinstalling OneCare. Activate with
the same LiveID that you originally subscribed with.
-steve
Stephen Boots
MVP Windows Live
Windows Live OneCare Forum Moderator
sboots@xxxxxx
Live OneCare Vista installation & setup
Live OneCare Vista General
Live OneCare 1.5 Vista General
Live OneCare Vista security
