Go Back   Vista Forums > Vista Newsgroups > Vista security
Vista Tutorial - admin and UAC problem
Old 01-06-2008   #1 (permalink)
bowler802
Guest
After setting up my new Vista Ultimate PC and getting tired of the UAC
prompts I turned it off. I have been an administrator on this system
from day one. After turnuing UAC off and rebooting the computer I
can no longer access My Microsoft Money file, when I turned on UAC I
can agian access the Money file. The sames happens with some "Real
Arcade games that were downloaded. I running the newest version of
Microsoft Money.
Can some one tell me what is happing and how to fix it so I can run
continue to be an administrator and turn off UAC, and still access my
files?
Old 01-06-2008   #2 (permalink)
Ken Blake, MVP
Guest
Re: admin and UAC problem
On Sun, 6 Jan 2008 07:14:35 -0800 (PST), bowler802
> Microsoft Money.
> files?
One of the disadvantages of turning off UAC is that certain programs
won't run that way, and that's one of the reasons I recommend against
turning it off. You've apparently discovered one of them. Another
program that won't run that way is the Adobe Reader installation.
Ken Blake, Microsoft MVP Windows - Shell/User
Please Reply to the Newsgroup
Old 01-06-2008   #3 (permalink)
Kerry Brown
Guest
You would have to reinstall the programs with UAC off. UAC affects how the
Vista registry and file virtualization behaves.
http://msdn2.microsoft.com/en-us/library/aa965884.aspx
http://support.microsoft.com/kb/927387
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca/phpBB2/
"bowler802" <mstyson@xxxxxx> wrote in message
news:8fb374ca-b97b-4d8a-8b73-631a63365767@xxxxxx
> Microsoft Money.
> files?
Old 01-06-2008   #4 (permalink)
JerryM
Guest
Ken,
Isn't there a way to set UAC to run continuously,
So the warning doesn't pop up every time?
I forgot where it is,
Jerry
"Ken Blake, MVP" <kblake@xxxxxx> wrote in message
news:cvu1o3d0orp7uoisre9qum1ngs9idmifj1@xxxxxx
>> Microsoft Money.
>> files?
Old 01-06-2008   #5 (permalink)
Dave
Guest
TweakUAC does that... it has a silent mode.
http://www.tweak-uac.com/download/
http://get.live.com/wlmail/overview
"JerryM" <jerrym526@xxxxxx> wrote in message
news:ucNM#uIUIHA.4476@xxxxxx
Quote:
> Ken,
> Jerry
>>> Microsoft Money.
>>> files?
Old 01-06-2008   #6 (permalink)
JerryM
Guest
Thanks, Dave
Jerry
"Dave" <dave@xxxxxx> wrote in message
news:e8r1yGJUIHA.484@xxxxxx
Quote:
>> Ken,
>> Jerry
<Snip>
Old 01-07-2008   #7 (permalink)
Knox
Guest
I have to wonder if the problem is virtualization.
Install problem app (Microsoft Money) with UAC turned on. Some files and
maybe resources are virtualized and put in the user folder. Now switch UAC
off and the program can no longer find the files it created to begin with.
That's because turning off UAC also turns off virtualization.
Not that anyone should turn off UAC, but if you re-installed the problem app
with UAC off, it might work.
Knox
Old 01-07-2008   #8 (permalink)
DevilsPGD
Guest
In message <9C373593-9486-4D76-BC4D-063B1F74E65A@xxxxxx> "Knox"
Another option, you can use a group policy to turn off UAC prompts, but
leave virtualization enabled.
Old 01-11-2008   #9 (permalink)
robin
Guest
I use tweakuac in silent mode
it turns off the administrator user but not the limited user and i find
EVERYTHING new can be installed with no problems. If you find a problem
then just go into tweakuc- put back the UAC until you install the program
and put it back on silent mode afterwards
robin
Quote:
>> Ken,
>> Jerry
>>>> Microsoft Money.
>>>> files?
Admin problem with vista General Discussion
Admin problem Vista account administration
Admin Problem Vista account administration
Another Admin Problem Vista account administration
