HELP HELP HELP multiple fake security alerts
  1. #1
    Kabouter Guest
    ive got at least three different alerts coming up in the bottom right of my
    screen on the toolbar warning me of security alerts and trojan alerts one
    says about some networm thing and the other has a load of stuff idont
    understand is there something i can down load to get rid of them. any advice
    would be greatly appreciated
  2. #2
    robin Guest
    Re: HELP HELP HELP multiple fake security alerts
    download and install SUPERantispyware
    http://superantispyware.com/superant...freevspro.html
    make sure you do the updates
    run the program and see what it finds.
    Once it is done see if it removes the trojans.
    download install sypybot search and destroy
    http://www.safer-networking.org/en/download/index.html
    run the program and see what if finds.
    If the trojans are still there
    Disconnect from the internet
    Go into Safe Mode and rerun Superantispware
    Let us know what happens
    robin
    download
    "Kabouter" <Kabouter@xxxxxx> wrote in message
    news:8373F18A-8D4A-4E3C-BAF7-0DFA67F3A6D8@xxxxxx
    > my
    > advice
  3. #3
    scrooge's Avatar
    home premium vista (64bit)
    Local Time: 08:46 PM
    run Windows Defender then some antivirus software. if you don't have antivirus software
    this one is free and works fine ...
    avast! antivirus software - computer virus, worm and Trojan protection by ALWIL Software
    mike
  4. #4
    Victek Guest
    > my
    > advice
    Download and run Smitfraudfix. You run the scan in normal windows mode and
    the cleanup in Safe Mode.
    I just goggled and found this link:
    http://www.afterdawn.com/software/de...itfraudfix.cfm
  5. #5
    Gerald3092 Guest
    Check for information here http://www.bluecollarpc.net/pcsafety.html
    Most likely you clicked some "free antispyware" at a web ? These are now
    common place stemming from the Zero Day WMFmetafile exploit in Windows which
    has since been patched (XP) about 2 years ago. Make sure you run Windows
    Updates - your computer operating system lifeline - for all
    Patches/Fix/Updates and install them. In the "zero day" security hole in
    Windows, cyber criminals were quick to do their nasty malware writing to
    create these fake products including SpyAxe, SpyFalcon, SpywareQuake and
    handfuls more. The Windows patch plugged the hole. On a new Vista currently
    there is about 50 to 60 Updates through Windows Updates to apply to get up
    to speed and security wise - fully patched.
    Try these to get rid of it:
    Ad-Aware [working-freeware, personal use - and premium version]
    http://www.lavasoftusa.com/software/adaware/
    Ad-Aware Personal provides advanced protection from known data-mining,
    aggressive advertising, Trojans, dialers, malware, browser hijackers, and
    tracking components. This software is downloadable free of charge for
    personal use.
    Microsoft AntiSpyware is now Windows Defender
    [working-freeware from Microsoft]
    http://www.microsoft.com/athome/secu...e/default.mspx
    Windows Defender is a free program that helps protect your computer against
    pop-ups, slow performance, and security threats caused by spyware and other
    unwanted software. It features Real-Time Protection, a monitoring system
    that recommends actions against spyware when it's detected, and a new
    streamlined interface that minimizes interruptions and helps you stay
    productive.
    SUPERAntiSpyware [working-freeware, and premium version]
    http://www.superantispyware.com/
    SUPERAntiSpyware scans your computer for known Spyware, Adware, Malware,
    Trojans, Dialers, Worms, KeyLoggers, HiJackers and many other types of
    threats, and allows you to remove or quarantine them. It offers daily
    (manual) definition updates, as well as home page hijack protection and
    customizable scan options. Furthermore, the program includes a Repair
    feature that allows you to restore various settings which are often changed
    by malware programs, but usually not corrected by simply removing the
    parasite. The free version lacks real-time blocking and protection as well
    as several other advanced options.
    a-squared trojan remover (Free Working Version for life and Proactive
    Premium Version)
    http://www.emsisoft.com/en/software/free/
    a-squared (a-squared) is a complementary product to antivirus software and
    desktop firewalls on MS Windows computers. Antivirus software specializes in
    detecting classic viruses. Many available products have weaknesses in
    detecting other malicious software (Malware) like Trojans, Dialers, Worms
    and Spyware (Adware). a-squared fills the gap that malware writers exploit.
    Automatic updates: In a-squared Free the updater must be run manually. The
    auto-update feature of a-squared Personal checks hourly for new available
    updates and installs them automatically. a-squared Free is freeware! You can
    download and use it completely for free. You are also allowed to distribute
    it to third parties. To be able to use it, you only must set up a free
    a-squared Account, to get access to the update server. (Note you register by
    simple sign up to activate definitions downloads free).
  6. #6
    ANTISPYWARESHIELD,SPYWARE.CYBERLOG-X. Guest
    RE: HELP HELP HELP multiple fake security alerts
    I HAVE RECEIVED THE MASAGE MENTIONED BELLOW
    YA COMPUTER HAS AFFCATED IN TROJAN VIRIOUS PLS DOWN LOAD THE ANTI SPY WARE
    KIT.
  7. #7
    Malke Guest
    > KIT.
    http://www.bleepingcomputer.com/forums/topic55288.html
    Malke
    MS-MVP
    Elephant Boy Computers
    www.elephantboycomputers.com
    Don't Panic!
  8. #8
    bb Guest
    In article <1C9D9A78-5EDC-405D-BF61-2A789E906595@xxxxxx>,
    ANTISPYWARESHIELD,SPYWARE.CYBERLOG-X.@xxxxxx says...
    > KIT.
    Yup, your computer is inflected - by a program that gives a message that
    your computer is inflected.
    You can try to remove it via normal malware programs (but *not* the
    program that it says to use!) but the only sure way is to reload Windows
    from scratch. There is a bonus for reloading, it'll run faster because
    it won't have all the crap ... ahhh ... installed programs that slow the
    *&^%! thing down.
    -bb
HELP HELP HELP multiple fake security alerts problems?
Fake Conficker Email Alerts Used Push Scareware. JMH System Security 0 20 Oct 2009
Watch out for fake virus alerts JMH System Security 1 30 Aug 2009
Windows security Alerts WaynwS Vista security 3 23 Sep 2008
Security Alerts Lynz1222 Vista security 2 17 Jul 2007
UAC and Security Alerts Ernie Vista security 3 10 Jun 2006
