Go Back   Vista Forums > Vista Newsgroups > Vista security
Vista - Problems conecting to a WIFI Network
Old 05-15-2008   #1 (permalink)
Ramiro Martín Fernández Llano
i have a client commputer with Windows Vista Ultimate installed, and i am
having problems logging on her wifi network. It doesn´t get the IP from the
router, i tested everything, i configued the network, the security password,
and i still can´t get into the network. She says me that it worked until
may, 9, and i saw in that date there were some updates installed on the
computer, but i can´t use the restore system, because it does´n do the
restoring, and i have the computer in the same place where i begin, without
no changes. Anyone, have any idea of how can i solve this problem. Any
help would be completely helpfull
Thank
ramiro Fernandez llano
Corrientes - Argentina
Old 05-19-2008   #2 (permalink)
Brandon.HK
RE: Problems conecting to a WIFI Network
Hello,
1. U can try to change the SSID in your router setting, i got your problem
b4. I just change the SSID and reflesh the setting, it can re-get the IP
sucessfully.
2. U can try to disable the password authentication, try to connect the
network for test the authentication has problem or not.
Begds/Brandon Chau
"Ramiro MartÃ*n Fernández Llano" wrote:
> having problems logging on her wifi network. It doesnt get the IP from the
> and i still cant get into the network. She says me that it worked until
> computer, but i cant use the restore system, because it doesn do the
> Thank
WiFi problems Network & Sharing
Problems with sound whe conecting LCD with PC through HDMI Sound & Audio
Wifi Problems Vista hardware & devices
Wifi problems Vista networking & sharing
For those of you having WiFi problems Vista networking & sharing
