Go Back   Vista Forums > Vista Newsgroups > Vista security
Vista - Help! Admin account problem
Old 06-06-2008   #1 (permalink)
vista home basic
I recently installed corel graphics suite 13 on my laptop. There was no problem with the installation.
However when i tried to open corel draw, it says
To start this application for the first time or to activate it, log in using an administrator level account, From then on you can use any user to open this application.
Now the issue is there is just one account in my laptop ..which of course is the admin account which is named different... in control panel under the users section i checked.
Maleeka
Administrator
<--- like that.
I opened in safe mode ...then corel draw opened ...den i switched back to regular mode ... its giving the same message.
Please help
Thanks
Old 06-06-2008   #2 (permalink)
Malke
Re: Help! Admin account problem
> Maleeka
> Administrator
> <--- like that.
So there's something in Regular Mode interfering. I would check with Corel
tech support since it's their product and/or post in their support
newsgroup.
cnews.corel.com
Malke
MS-MVP
Elephant Boy Computers
www.elephantboycomputers.com
Don't Panic!
Old 06-06-2008   #3 (permalink)
Victek
> Maleeka
> Administrator
> <--- like that.
> Please help
In regular mode try "right-clicking" on the Corel icon and select "run as
administrator".
Problem running old program on non-admin account Software
How to set Admin password from an admin user account Vista General
Beyond a normal Admin issue. Admin account is acting as a guest ac Vista account administration
Admin Account Problem: Windows Live Messenger Vista account administration
problem with admin account Vista account administration
