| | Problems with the "Require trusted path for credential entry" setting Hi After reading http://technet.microsoft.com/da-dk/m...19(en-us).aspx, i want to try the recommandation to use "Require trusted path for credential entry" when evaluate to administrator. After activating this settings, i selected windows update and chose "run as administrator", then a dialog came and I pressed ctrl+alt+del to access the "secure desktop". The screen change to the startup screen, with the text "please wait". Then no more happened. I left it on for a 5 - 10 min, but nothing happens. Then the only options was to power off the computer, return to safe mode and deactivate the settings. Anyone knows why this happens??? rrm |
| | Re: Problems with the "Require trusted path for credential entry" setting "rrm" <runemadsen16@xxxxxx> wrote in message news p.uho4kuz0b2lo77@xxxxxxQuote: > Hi > > After reading > http://technet.microsoft.com/da-dk/m...19(en-us).aspx, i want > to try the recommandation to use "Require trusted path for credential > entry" when evaluate to administrator. After activating this settings, i > selected windows update and chose "run as administrator", sometimes a reboot is needed for some settings to actually take. Quote: > then a dialog came )Quote: > and I pressed ctrl+alt+del to access the "secure desktop". The screen > change to the startup screen, with the text "please wait". Then no more > happened. I left it on for a 5 - 10 min, but nothing happens. Then the > only options was to power off the computer, return to safe mode and > deactivate the settings. |
| | Re: Problems with the "Require trusted path for credential entry"setting Den 19.09.2008 kl. 00:26 skrev FromTheRafters <erratic@xxxxxx>: Quote: > "rrm" <runemadsen16@xxxxxx> wrote in message > news p.uho4kuz0b2lo77@xxxxxxQuote: >> Hi >> >> After reading >> http://technet.microsoft.com/da-dk/m...19(en-us).aspx, i want >> to try the recommandation to use "Require trusted path for credential >> entry" when evaluate to administrator. After activating this settings, i >> selected windows update and chose "run as administrator", > Did you reboot? I'm not sure it is needed, but > sometimes a reboot is needed for some settings > to actually take. evaluation still is shown!?!? Quote: Quote: >> then a dialog came > Could you be more vague? )and "Would you do not complete the action". After clicking on the first, a dialog is shown to press ctrl+alt+del and after i have pressed this, then my problem occur. Quote: Quote: >> and I pressed ctrl+alt+del to access the "secure desktop". The screen >> change to the startup screen, with the text "please wait". Then no more >> happened. I left it on for a 5 - 10 min, but nothing happens. Then the >> only options was to power off the computer, return to safe mode and >> deactivate the settings. > |
| | Re: Problems with the "Require trusted path for credential entry" setting "rrm" <runemadsen16@xxxxxx> wrote in message news p.uhpvxjjkb2lo77@xxxxxxQuote: > Den 19.09.2008 kl. 00:26 skrev FromTheRafters <erratic@xxxxxx>: > Quote: >> "rrm" <runemadsen16@xxxxxx> wrote in message >> news p.uho4kuz0b2lo77@xxxxxxQuote: >>> Hi >>> >>> After reading >>> http://technet.microsoft.com/da-dk/m...19(en-us).aspx, i want >>> to try the recommandation to use "Require trusted path for credential >>> entry" when evaluate to administrator. After activating this settings, i >>> selected windows update and chose "run as administrator", >> Did you reboot? I'm not sure it is needed, but >> sometimes a reboot is needed for some settings >> to actually take. > I did not rebot after changing the setting.... But i suppose the old > evaluation still is shown!?!? appears that the setting was applied properly. Quote: Quote: Quote: >>> then a dialog came >> Could you be more vague? )> Well the dialog has two options: "Would you like you complete the action" > and "Would you do not complete the action". After clicking on the first, a > dialog is shown to press ctrl+alt+del and after i have pressed this, then > my problem occur. did everything correctly, but something is amiss with either the secure desktop switching or something else related to "consent.exe" hanging. Maybe someone else here has seen this or something similar and can help you. A quick Google search did not turn up anything for me specifically related to this. Quote: Quote: Quote: >>> and I pressed ctrl+alt+del to access the "secure desktop". The screen >>> change to the startup screen, with the text "please wait". Then no more >>> happened. I left it on for a 5 - 10 min, but nothing happens. Then the >>> only options was to power off the computer, return to safe mode and >>> deactivate the settings. |
| "ViewEntireForest": "Active Directory operation failed on . Thesupplied credential for | PowerShell | |||
| In Outlook Express, how can I define the "columns" other than the "InBox" setting | Live Mail | |||
| How to change "require trusted path for credential entry" | Vista account administration | |||
| "Open command prompt here" and "Copy as path" | Vista performance & maintenance | |||
| PSSnapIn InstallUtil Problem -- "That assembly does not allow partially trusted callers.." | PowerShell | |||
