| | UAC and Control Panel access problem Please could someone help me. I've just installed Vista Business Upgrade on a brand new Dell laptop (XP pro). When I try to access some of the links in Control Panel I get a 'file not found' error. This happens with system / remote settings; system / system protection and system / adavcned system settings amonght others. system/ device manager asked for authorisation (as it should). The only way I can get this to work is by disabling UAC, then all the links work OK. Any ideas, thanks. |
| control panel access | General Discussion | |||
Can't Access NVIDIA Control Panel | Graphic cards | |||
| cannot access control panel | General Discussion | |||
| Control Panel access | Vista General | |||
| Control Panel Access | Vista performance & maintenance | |||
