| | RE: Please Help me with security center problem I had this same problem. My computer has a 64 bit processor and came with Vista Home Premium (32 bit) already installed. Windows Security Center recognized every security program I evaluated. I then reformatted my hard drive and did a clean install upgrade to Vista Ultimate (64 bit). I had to do a clean install because you cannot update a 64 bit OS over a 32 bit OS. Windows Security Center recognized all security software I evaluated on it. However, the lack of 64 bit software applications forced me to go with the Vista Ultimate 32 bit. I reformatted my hard drive and did a clean install of Vista Ultimate 32 bit. Windows Security Center WOULD NOT recognize any security software, not even Windows Defender and Windows Live One Care. I know they were operating properly because I watched them in Process Explorer and Task Manager. The software also properly updated itself. Windows Security Center would not recognize the software even after I ran the software and rebooted several times. I then called Microsoft. I talked with them for appx. one hour before they finally made the decision to close the case as unsolved. I then reformatted my hard drive once again, reinstalled the OEM Vista Home Premium and upgraded to Vista Ultimate 32 bit. I don't know why but the problem has been solved. Windows Security Center now recognizes any and all security software installed and running. However, please be advised that if you install Windows Live One Care it will disable Windows Defender as Windows Defender has been "incorporated" into Live Once Care. The good part in all of this is that it takes me only 15 minutes to do a clean install of any of the Vista operating systems and only 20 minutes for the upgrade. I don't know why this is so. I don't have a superfast computer. I am running an AMD Athlon x64 4200 dual core processor on a Dell E-521 desktop, 320 GB hard drive, 2 GB of dual channel memory and an ATI Radeon x1300 pro graphics card. As you can see, this system is nothing special. "Inferno" wrote: > I have just done an upgrade of vista ultimate i am using nod32 AV i am having > problems where security center wont recognise it and also will not allow me > to turn on windows defender or update it.I do not want to have to monitor it > mysel just laziness i guess but i would like security center to monitor it > for me.Any suggestions please |
| Problem with my security center. | System Security | |||
| Norton Internet Security 2008 and Vista's Security Center | Vista security | |||
| Vista Security Center Aero Problem? | Vista security | |||
| Problem with Windows Security Center not seeing my Antivirus Program | Vista installation & setup | |||
| Re: Please Help me with security center problem | Vista security | |||
