Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Go Back   Vista Forums > Vista Newsgroups > Vista security
HELP!!!!!!!!!!! Unlocking the "Lock" on vista
LinkBack Thread Tools Display Modes
Old 08-05-2007   #1 (permalink)
JackieD
Guest
I'm new to vista... and see there is a lock function (son found it when
accessing the Task Management) and he accidently hit lock... my question is..
how do you unlock it? or will it reset when I shut down the computer? I
assume I need to use my password to get back into my user (its password
protected)??? I'm not sure whether to shut down the computer incase I can
never get back in again... lol..
Old 08-05-2007   #2 (permalink)
Paul Smith
Guest
Re: HELP!!!!!!!!!!! Unlocking the "Lock" on vista
"JackieD" <JackieD@discussions.microsoft.com> wrote in message
news:25321184-A193-46DB-9A51-EC84F720E31B@microsoft.com...
> is..
You can just click on your user picture on the lock screen or enter your
password to login again.
It's basically designed so if you're stepping away from your machine for a
few minutes you can lock the machine to prevent somebody else from snooping
around on your desktop, then when back login again. In fact it works the
same as the 'switch user' feature, in that it keeps you logged onto the
system, but requires you to click your user picture or enter a password to
show your desktop.
Paul Smith,
Yeovil, UK.
Microsoft MVP Windows Shell/User.
http://www.dasmirnov.net/blog/
http://www.windowsresource.net/
*Remove nospam. to reply by e-mail*
Old 08-06-2007   #3 (permalink)
Gary G. Little
Guest
He more than likely fat-fingered the Windows+L key combination. I use that
every evening to lock access to my system. Alternately he selected "lock"
from the Start menu.
Like Pul said, select your icon or login name and log in.
The personal opinion of
Gary G. Little
"Paul Smith" <Paul@nospam.windowsresource.net> wrote in message
news:uNNpCf41HHA.1100@TK2MSFTNGP06.phx.gbl...
>> is..
> snooping around on your desktop, then when back login again. In fact it
> works the same as the 'switch user' feature, in that it keeps you logged
> onto the system, but requires you to click your user picture or enter a
> password to show your desktop.
> Paul Smith,
> Yeovil, UK.
Old 08-06-2007   #4 (permalink)
JackieD
Guest
Thanks Paul..
> > is..
> show your desktop.
> Paul Smith,
> Yeovil, UK.
Old 08-06-2007   #5 (permalink)
JackieD
Guest
Thanks Gary... appreciate your help..
> Gary G. Little
> >> is..
> > Paul Smith,
> > Yeovil, UK.
Display Modes
Use "lock" in three methods to prevent shared-memory corruption Curious .NET General 5 07-31-2008 12:05 PM
Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" Platebanger Vista General 6 02-05-2008 08:54 AM
Can't lock DVD drive ("access denied") for burning Bruce Phillips Vista General 2 10-15-2007 08:08 AM
Dual monitors "flip" when unlocking PC John R. Lewis, MCP Vista General 3 03-22-2007 02:07 AM
WM5 Sync with Vista "Windows Calender", "Contacts", and "Mail" Tony Vista General 1 02-16-2007 06:20 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
