br> br> |
| | Thread Tools | Display Modes |
| Guest | Connection problem My VB 6 program uses this connection string to connect to the server: user id=coord;data source=GS;persist security info=True;Password=coord;initial catalog=CoordinatorTest It works fine on all XP machines, but it doesn't work on only some of Vista Business machines. It says Server doesn't exists or access denied. On some other Vistas it works. When I replace the name of the SQL Server with IP: user id=coord;data source=10.22.52.4;persist security info=True;Password=coord;initial catalog=CoordinatorTest then it works. I wouldn't want to create the different Connection strings for different operating systems. What's wrong with some of non working Vista's machines? What should be done in order to make all of Vista machines work? Thank you vovan |
| | #2 (permalink) | ||||||||||||
| Guest | Re: Connection problem "vovan" <v@xxxxxx> wrote in message news:%23v2T$CGEIHA.3332@xxxxxx
but not by hostname. You'd want to troubleshoot this as a general TCP/IP Name resolution problem - make sure DNS Settings are correct; does a "ping <hostname> from an Vista Command Line give same results as "ping <IP address>"?; etc. The Netdiag tool from the XP Support Tools also runs on Vista; just copy over the netdiag.exe file from XP. Then run C:\FOO>netdiag /v /debug on the Vista machine, to run a comprehensive test for DNS and Domain problems. You don't say whether you're using ODBC, OLE DB, SQL Native Client, or what; but generally, they should all work on Vista much the same as on XP. More likely to be networking than compatibility, I'd guess. Hope it helps, -- Andrew McLaren amclar (at) optusnet dot com dot au | ||||||||||||
| Display Modes | |
| Mac to PC connection problem | lb | Vista networking & sharing | 7 | 06-23-2008 03:45 PM |
| USB Connection problem | Kal | Vista hardware & devices | 1 | 02-24-2008 02:34 PM |
| another connection problem | Len | Vista networking & sharing | 1 | 01-17-2008 05:02 AM |
| Connection problem | Budgie | Vista General | 1 | 06-29-2007 10:32 PM |
| WRE connection problem | Mikko24 | Vista networking & sharing | 0 | 06-19-2007 04:49 AM |
