Go Back   Vista Forums > Misc Newsgroups > WinFX General
Vista Tutorial - ENTERING PRODUCT KEYS MONEY PLUS
Old 01-12-2008   #1 (permalink)
melrose
Guest
To activate Money Plus Deluxe from CD, when I enter the Product Keys, the
boxes in which one enters the keys do not accept the fifth key and hence not
able to activate the product. Any solution?
Melrose
Old 03-01-2008   #2 (permalink)
sredwing
Guest
RE: ENTERING PRODUCT KEYS MONEY PLUS
reset font to default
having same problem just.... found the solution your font size is set to
large you must reset font size to default to reduce font size and enable it
to accept 5th charachter
> Melrose
Reinstallation possible without re-entering product key? Vista installation & setup
Entering Product Key during Installation Vista installation & setup
Vista Home Basic Upgrade Setup Freezes after entering Product Key Vista installation & setup
Unable to get past entering in product key Vista installation & setup
Beta 2 Intall Dies After Entering Product Key Vista installation & setup
