Go Back   Vista Forums > Misc Newsgroups > WinFX General
Vista Tutorial - explorer.exe wont load on startup
Old 04-09-2008   #1 (permalink)
hoodster 2004
Guest
explorer.exe wont load on startup i have windows vista home premium. It just
opens up with my documents folder.
Old 04-09-2008   #2 (permalink)
1337 spammer
Windows 7 RC
Re: explorer.exe wont load on startup
Quote  Quote: Originally Posted by hoodster 2004 View Post
Try this fix:
1. click start> type regedit.
2. Navigate to the following HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogo n
3. The little key 8th one from the bottom should be "Shell"
4. Double click it and in the value date it should say Explorer.exe if it doesn't then type that in there.
5. Hit Ok and restarted your machine.
Let us know if that worked for you.
Old 04-19-2008   #3 (permalink)
Newbie
Vista Ultimate 32bit SP1
Hi
I had a Trojan Horse detected with my antivirus I tried to fix it using the recommendations from antivirus, it seems to work until ...
My system didint load exploere from startup, it hangs showing me my documents folder...
I hited ctrl+alt+del to show on the task manager than run Explorer.exe and the system starts and everything working fine, except that now i need to do that every time i start the computer.
performed a search and found this forum...
I have this line in this 8th key
Shell = Explorer.exe C:\WINDOWS\Config\lsass.exe
should I delete the "C:\WINDOWS\Config\lsass.exe" leaving the Explorer.exe alone?
Old 04-23-2008   #4 (permalink)
Newbie
Vista Home Premium 32bit
Yes you need to ete td on info, mine said exacthly the same, i deleted the extra tex to leave Explorer.exe then restart machine and it should work, any other probs add me on msn at longy3_spunk@hotmail.com or email me at same addy
Aleks
Old 04-30-2008   #5 (permalink)
ravenfaust
Guest
Same problem explorer wont load but loads a documents folder instead on
starup, i use the CTRL+ALT=DELT and use the run command to start Explorer.exe
> work, any other probs add me on msn at longy3_spunk@xxxxxx or email
> me at same addy
> Aleks
> longsville
Old 06-18-2008   #6 (permalink)
Newbie
Vista Home Premim 32bit
Thanks a lot this worked great.
What was in the shell file was:
explorer.exe C:\WINDOWS\Config\Csrss.exe
Any idea what the additional exe file may be?
Quote  Quote: Originally Posted by .Joe View Post
Try this fix:
Old 06-19-2008   #7 (permalink)
Newbie
Im guessing that it is caused either byu a virus, or more likely an internet explorer add on that does not like a certain file....it happened to me a second time so im leaning towards an IE add on.....
let me know if there are anymore problems
Old 07-14-2008   #8 (permalink)
Klexur
Guest
I am having the same problem but I have XP and it only loads the wallpaper
and mouse. I had this same problem before i reformatted my hard drive . How
can I fix this?
> > me at same addy
> > Aleks
> > longsville
Old 07-24-2008   #9 (permalink)
OneOfThree
Guest
Thank you, Thank you, Thank you!! I had the same problem. Your fix worked. I
also had the same "explorer.exe C:\WINDOWS\Config\Csrss.exe " in my registry.
I can't tell you how relieved I am. Thanks ONE MORE TIME!
> longsville
Old 08-10-2008   #10 (permalink)
Elite Gamer
Hey, I just found some info on this problem that looks like it hasn't been posted yet.
First off, here is a report on csrss.exe
Quote:
csrss.exe is the main executable for the Microsoft Client/Server Runtime Server Subsystem. This process manages most graphical commands in Windows. This program is important for the stable and secure running of your computer and should not be terminated.
Also, you may want to try something like this:
Code:
Explorer.exe;C:\WINDOWS\Config\csrss.exe
Event Viewer wont load / Explorer crash General Discussion
Web Slices wont load Browsers & Mail
os wont load and start Vista General
Startup program wont load Vista General
pc cillin wont load Vista General
