Go Back   Vista Forums > Misc Newsgroups > WinFX General
Vista - ServiceApplication problem
Old 09-06-2006   #1 (permalink)
SubZero
Hello,
When my service (a SYSTEM service) start type is set to auto, Windows in
Safe mode login screen crashes. It does not let the user to log in! Simply
reboots! This is both on my computer and customer computer away in
Sweden. Any idea? Is this a Windows bug? When I set the startup type to
"manual" and try to manually start the service in Safe mode, it says "cannot
start in safe mode" but I do not understand why it crashes the entire
windows XP! (I did not try with Vista)
Best Regards,
SubZero
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
fixed unable to delete email problem, now I have new problem Vista mail
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
