Go Back   Vista Forums > Misc Newsgroups > WinFX General
Vista - How do I distinguish between 32 & 64-bit vista?
Old 09-22-2006   #1 (permalink)
=?Utf-8?B?Sm9obiBFbGxpb3R0?=
Vista 32 & 64 both report the same OS version.
Existing code that worked for previous Microsoft OS:
// Get the version information
Version vs = os.Version;
PlatformID p = os.Platform;
case System.PlatformID.Win32NT:
switch(vs.Major)
case 5:
if (vs.Minor == 0)
return "Windows 2000 " + os.Version.ToString();
else if (vs.Minor == 1)
return "Windows XP " + os.Version.ToString();
else if (vs.Minor == 2)
return "Windows XP 64 " + os.Version.ToString();
else
return "Unknown Windows NT: " + os.Version.ToString();
case 6:
if (vs.Minor == 0)
return "Windows Vista " + os.Version.ToString();
else
return "Windows Vista 64 " + os.Version.ToString();
// assumption for now
default:
return ("Win32NT family:" + vs.Major.ToString() + "." +
vs.Minor.ToString() + " ->" + os.VersionString);
Vista 32 & 64 both report the same version.
Old 10-19-2006   #2 (permalink)
Bryan Phillips
Re: How do I distinguish between 32 & 64-bit vista?
Would this work?
Console.WriteLine("This is a {0}-bit OS.", IntPtr.Size * 8);
Bryan Phillips
MCSD, MCDBA, MCSE
Blog: http://bphillips76.spaces.live.com
"John Elliott" <JohnElliott@discussions.microsoft.com> wrote in message
news:3A536541-269B-432E-B591-75B2D9DEE891@microsoft.com:
> switch(vs.Major)
> case 5:
> if (vs.Minor == 0)
> else
> case 6:
> if (vs.Minor == 0)
> else
> default:
Re: How to distinguish one PowerShell from another. PowerShell
