| | ANN: September CTP Microsoft Pre-Release Software Microsoft .NET Framework 3.0 - September CTP http://www.microsoft.com/downloads/d...0-5d3ccd3d94ed Readme http://msdn.microsoft.com/windowsvis...P/default.aspx -- Thomas Scheidegger - MVP .NET - 'NETMaster' http://www.cetus-links.org/oo_dotnet.html - http://dnetmaster.net/ |
| | Re: September CTP > Microsoft Pre-Release Software Microsoft .NET Framework 3.0 - September CTP Microsoft Visual Studio Code Name 'Orcas' Community Technology Preview - Development Tools for .NET Framework 3.0 SeptCTP http://www.microsoft.com/downloads/d...9-4ae083033d09 -- Thomas Scheidegger - MVP .NET - 'NETMaster' http://www.cetus-links.org/oo_dotnet.html - http://dnetmaster.net/ |
| | Re: ANN: September CTP On Fri, 22 Sep 2006 19:02:09 +0200, "Thomas Scheidegger [MVP]" <spam.netmaster@swissonline.ch> wrote: > >Microsoft Pre-Release Software Microsoft .NET Framework 3.0 - September CTP > http://www.microsoft.com/downloads/d...0-5d3ccd3d94ed > >Readme > http://msdn.microsoft.com/windowsvis...P/default.aspx In what order do I remove the RC1 components? The readme above has a link to a page containing this info, but that page is way out of date and refers to Beta 1 and Beta 2 installs that I do not have. Specifically, I have the .NET runtime, the Windows SDK, and the Orcas install. Thanks, Chuck |
| | Re: September CTP ....and the SDK: Microsoft Windows SDK (ISO) for September CTP http://www.microsoft.com/downloads/d...6-BF058766A9FF Release Notes http://download.microsoft.com/downlo...leaseNotes.Htm Blog http://blogs.msdn.com/windowssdk/ -- Thomas Scheidegger - MVP .NET - 'NETMaster' http://www.cetus-links.org/oo_dotnet.html - http://dnetmaster.net/ |
| | Re: ANN: September CTP > In what order do I remove the RC1 components? it is recommended to test on a clean machine... Else try Pre-released Microsoft .NET Framework 3.0 Uninstall Tool http://www.microsoft.com/downloads/d...F-E85AA9E66146 -- Thomas Scheidegger - MVP .NET - 'NETMaster' http://www.cetus-links.org/oo_dotnet.html - http://dnetmaster.net/ |
| | #6 (permalink) |
| | Re: ANN: September CTP On Thu, 28 Sep 2006 23:35:34 +0200, "Thomas Scheidegger [MVP]" <spam.netmaster@swissonline.ch> wrote: > > In what order do I remove the RC1 components? > > >it is recommended to test on a clean machine... >Else try > Pre-released Microsoft .NET Framework 3.0 Uninstall Tool > http://www.microsoft.com/downloads/d...F-E85AA9E66146 The instructions for this download say: "This article describes how to uninstall pre-release versions of Microsoft .NET Framework 3.0 if the typical uninstall process is unsuccessful." And further down: "If your computer has a pre-release version on it, follow the Uninstall Instructions below to uninstall these pre-release bits before installing the Microsoft ..NET Framework CTP. You must remove them in the correct order to ensure a clean uninstall." So, my question is, what is the correct order? The uninstall instructions mentioned above are seriously out of date, they refer to Beta 1 and 2 products and don't mention the SDK or Orcas components. I installed the June/July CTP's and their uninstallers worked fine. Thanks, Chuck |
| | #7 (permalink) |
| | Re: ANN: September CTP I ended up uninstalling in reverse order from what I could remember: -- Orcas -- Windows SDK -- .NET Framework 3.0 That worked fine for me. Chuck |
| [ANN] New PowerShell programming book due in September | PowerShell | |||
| New Realtek audio drivers 30 September | Vista hardware & devices | |||
| Will Vista RC 1 arrive September 7th ? | Vista General | |||
