Go Back   Vista Forums > Misc Newsgroups > WinFX General
Vista - Read strings from resource DLL, WinFX , C#
Old 11-06-2006   #1 (permalink)
keerthana_m_2003@yahoo.com
Hi All:
I have a resource WinFX satellite DLL generated by specifying culture
in VCPROJ. (The en-US DLL is then used by LOCBAML tool for generating
other language DLL's).
Is there a way to parse the resource DLL in code? In general, it is
suffecient to specify CurrentCulture, BUT I need to parse the DLL in
the code and get the strings based on UIDs. Are there any API's in C#
to do the same?
Thanks
Keerthana
read strings to variable VB Script
How to extract sub-strings? VB Script
-f paramater in strings PowerShell
Resource strings PowerShell
