| | Trying to use WPF, I get many schema errors Hi, Using the latest RC1 WPF, I get schema errors like below. Where can I find the definition of these schemas? (e.g. http://schemas.microsoft.com/winfx/2.../presentation). I don't care if they are temporary and subject to change...anything is better than driving blind... Thanks! ------------------------------------------ Warning 1 The element 'Viewport3D' in namespace 'http://schemas.microsoft.com/winfx/2006/xaml/presentation' has invalid child element 'Viewport3D.Children' in namespace 'http://schemas.microsoft.com/winfx/2006/xaml/presentation'. List of possible elements expected: 'Viewport3D.Camera, Viewport3D.Style, Viewport3D.OverridesDefaultStyle, Viewport3D.Triggers, Viewport3D.Resources, Viewport3D.DataContext, Viewport3D.Language, Viewport3D.Tag, Viewport3D.InputScope, Viewport3D.LayoutTransform, Viewport3D.Width, Viewport3D.MinWidth, Viewport3D.MaxWidth, Viewport3D.Height, Viewport3D.MinHeight, Viewport3D.MaxHeight, Viewport3D.Margin, Viewport3D.FocusVisualStyle, Viewport3D.Cursor, Viewport3D.ForceCursor, Viewport3D.ToolTip, Viewport3D.ContextMenu, Viewport3D.InputBindings, Viewport3D.CommandBindings, Viewport3D.AllowDrop, Viewport3D.RenderSize, Viewport3D.RenderTransform, Viewport3D.RenderTransformOrigin, Viewport3D.Opacity, Viewport3D.OpacityMask, Viewport3D.BitmapEffect, Viewport3D.BitmapEffectInput, Viewport3D.ClipToBounds, Viewport3D.Clip, Viewport3D.SnapsToDevicePixels, Viewport3D.IsEnabled, Viewport3D.I****TestVisible, Viewport3D.Focusable, sgVisual3D, ModelVisual3D' in namespace 'http://schemas.microsoft.com/winfx/2006/xaml/presentation'. C:\Documents and Settings\Juan Dent\My Documents\MSDN\Windows Presentation Foundation Hands-On-Labs\LNGW702 - Creating Rich 2D and 3D Content in WPF\Source\Ex3\Final\RichContent\Window1.xaml 21 6 RichContent ------------------ -- Thanks in advance, Juan Dent, M.Sc. |
| | Re: Trying to use WPF, I get many schema errors Hello, these are warnings, if the project builds and runs, there is no problem, maybe the IDE you're using isn't up to date. The schema file can be found here: <VS2005 Install Dir>\Xml\Schemas\Xaml2005.xsd if you have Orcas installed. I think the IDE is Visual Studio, because this is kind of a known issue. Take a peek in Rob Relyea's blog: http://www.windows-now.com/blogs/rre.../07/14167.aspx All the best, Andrei Iacob Juan Dent wrote: > Hi, > > Using the latest RC1 WPF, I get schema errors like below. Where can I find > the definition of these schemas? (e.g. > http://schemas.microsoft.com/winfx/2.../presentation). > I don't care if they are temporary and subject to change...anything is > better than driving blind... > > Thanks! > > > ------------------------------------------ > Warning 1 The element 'Viewport3D' in namespace > 'http://schemas.microsoft.com/winfx/2006/xaml/presentation' has invalid child > element 'Viewport3D.Children' in namespace > 'http://schemas.microsoft.com/winfx/2006/xaml/presentation'. List of possible > elements expected: 'Viewport3D.Camera, Viewport3D.Style, > Viewport3D.OverridesDefaultStyle, Viewport3D.Triggers, Viewport3D.Resources, > Viewport3D.DataContext, Viewport3D.Language, Viewport3D.Tag, > Viewport3D.InputScope, Viewport3D.LayoutTransform, Viewport3D.Width, > Viewport3D.MinWidth, Viewport3D.MaxWidth, Viewport3D.Height, > Viewport3D.MinHeight, Viewport3D.MaxHeight, Viewport3D.Margin, > Viewport3D.FocusVisualStyle, Viewport3D.Cursor, Viewport3D.ForceCursor, > Viewport3D.ToolTip, Viewport3D.ContextMenu, Viewport3D.InputBindings, > Viewport3D.CommandBindings, Viewport3D.AllowDrop, Viewport3D.RenderSize, > Viewport3D.RenderTransform, Viewport3D.RenderTransformOrigin, > Viewport3D.Opacity, Viewport3D.OpacityMask, Viewport3D.BitmapEffect, > Viewport3D.BitmapEffectInput, Viewport3D.ClipToBounds, Viewport3D.Clip, > Viewport3D.SnapsToDevicePixels, Viewport3D.IsEnabled, > Viewport3D.I****TestVisible, Viewport3D.Focusable, sgVisual3D, ModelVisual3D' > in namespace > 'http://schemas.microsoft.com/winfx/2006/xaml/presentation'. C:\Documents and > Settings\Juan Dent\My Documents\MSDN\Windows Presentation Foundation > Hands-On-Labs\LNGW702 - Creating Rich 2D and 3D Content in > WPF\Source\Ex3\Final\RichContent\Window1.xaml 21 6 RichContent > ------------------ > > -- > Thanks in advance, > > Juan Dent, M.Sc. |
| XML with schema | .NET General | |||
| Need to program it anyone know schema | Live Mail | |||
| Help With Program Created XML Schema | .NET General | |||
| Extracting schema.. | .NET General | |||
