| | problem in raising privilege level using manifest resource This issue is in Vista. I used XML files(one for DLLs, other for EXEs) ane embeded them in my EXEs and all DLLs ....actually i want to spawn a third party setup from found new hardware...but an error message is shown "illegel value: requestedrunlevel" and setup failed to spawn... Someone please tell me how to elevate the setup files so that setup can be spawned from found new hardware... I used following code: <?xml version="1.0" encoding="UTF-8" standalone="yes"?> <assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0"> <assemblyIdentity version="1.0.0.0" processorArchitecture="X86" name="temp10" type="win32"/> <description>Privelidged</description> <trustInfo xmlns="urn:schemas-microsoft-com:asm.v3"> <security> <requestedPrivileges> <requestedExecutionLevel level="requireAdministrator" uiAccess="true"/> </requestedPrivileges> </security> </trustInfo> </assembly> Thanks and Regards, Ajay |
| | Re: problem in raising privilege level using manifest resource uiAccess needs to false except for UI Accessible applications. In order to get this to work, the components involved are going to need to be signed. See these links for more info: UI Automation Security Overview ms-help://MS.MSSDK.1033/MS.NETFX30SDK.1033/wpf_conceptual/html/1d853695-973c-48ae-b382-4132ae702805.htm Developer Best Practices and Guidelines for Applications in a Least Privileged Environment http://msdn2.microsoft.com/en-us/library/aa480150.aspx -- Bryan Phillips MCSD, MCDBA, MCSE Blog: http://bphillips76.spaces.live.com Web Site: http://www.composablesystems.net "erajaysharma@gmail.com" <erajaysharma@gmail.com> wrote in message news:1174491169.426349.9040@p15g2000hsd.googlegroups.com: > This issue is in Vista. > I used XML files(one for DLLs, other for EXEs) ane embeded them in my > EXEs and all DLLs ....actually i want to spawn a third party setup > from found new hardware...but an error message is shown "illegel > value: requestedrunlevel" > and setup failed to spawn... Someone please tell me how to elevate the > setup files so that setup can be spawned from found new hardware... > > I used following code: > > <?xml version="1.0" encoding="UTF-8" standalone="yes"?> > <assembly xmlns="urn:schemas-microsoft-com:asm.v1" > manifestVersion="1.0"> > <assemblyIdentity version="1.0.0.0" > processorArchitecture="X86" > name="temp10" type="win32"/> > <description>Privelidged</description> > <trustInfo xmlns="urn:schemas-microsoft-com:asm.v3"> > <security> > <requestedPrivileges> > <requestedExecutionLevel > level="requireAdministrator" uiAccess="true"/> > </requestedPrivileges> > </security> > </trustInfo> > </assembly> > > Thanks and Regards, > Ajay |
| detect user privilege level | General Discussion | |||
| Compatibility Tab Privilege Level greyed out | Vista security | |||
| Compatibility-Privilege Level | Vista General | |||
| privilege level grayed out? | Vista account administration | |||
| Privilege Level on Shortcuts Grayed Greyed Out | Vista General | |||
