Go Back   Vista Forums > Misc Newsgroups > WinFX General
Vista - Sequence of steps using workflow foundation in ASP.NET
Old 04-11-2007   #1 (permalink)
Jimmy
I started to know about WF in ASP.NET when I looked into
http://www.masteringbiztalk.com/atlasworkflowdesigner
I have a similar requirement. My objective is that I need to have
similar UI. But I need to have an execute button which will do some
processing based on the workflow generated using drag and drop. How
can I do that ? I mean, is the workflow saved somewhere where from I
can parse it and fire different tasks based on the activity sequence ?
Is it necessary to use database to save the workflow ? Can't I use an
xml file ?
Achintya
any way for PowerShell and Windows Workflow Foundation to integrate? PowerShell
