Go Back   Vista Forums > Misc Newsgroups > WinFX General
Vista - AllowTransparency=True = CPU > 90%
Old 05-31-2007   #1 (permalink)
Just this question for people who can confirm this:
- A WPF normal window is rendered by GPU acceleration
- A WPF window with AllowTransparency="True" is rendered by CPU
The question is here cause I saw the performance are very bad when moving or
resizing (by event + code)
It true, the next question is why WPF doesn't use GPU for transparent window
Thx
-Vince
Old 06-01-2007   #2 (permalink)
Laurent Bugnion, MVP
Re: AllowTransparency=True = CPU > 90%
vrithner@hotmail.com wrote:
> Hi,
> moving or
> window
> Thx
> -Vince
That's correct on XP, but the good news is that transparent windows are
hardware accelerated on Vista. I am not sure what the exact reason is.
As an alternative, if you do CPU-intensive stuff in a transparent
window, you can use a Win32 window and include your WPF stuf into it.
HTH,
Laurent
Laurent Bugnion [MVP ASP.NET]
Software engineering, Blog: http://www.galasoft-LB.ch
PhotoAlbum: http://www.galasoft-LB.ch/pictures
Support children in Calcutta: http://www.calcutta-espoir.ch
Operator -not should get True for whatever -eq 0 gets True (and morefun) PowerShell
True number of true Vista users Vista General
